Tesla Large Drive Control Board
Ricardo72
Post by Ricardo72 »
I'm new to the forum. Interested in converting a 750 and looking to use a Tesla Large Drive. I'm looking for the control board to buy
Has thanked: 369 times
Been thanked: 1544 times
Re: Tesla Large Drive Control Board
You will find this board in the openinverter shop starting middle of June.
Ricardo72
Post by Ricardo72 »
johu wrote: Sat May 09, 2020 7:51 pm You will find this board in the openinverter shop starting middle of June.
Thanks. I was able to the files
Regarding the board build. I'm getting not that from the BOM i have to source three items myself. Is this normal. No issue with finding them myself soldering them. I'm just interested in knowing if this is normal.
Permag
Post by Permag »
The LDU does not rotate when the throttle is engaged and then shows OVERCURRENT lasterr. There are no errors when ignition is turned on or when the start button is pressed. The motor shows that it’s in RUN mode, but when the throttle is engaged we get the OVERCURRENT error.
Elektro-Funken RSR/#P85DPorsche.
Youtube video:
https://www.youtube.com/watch?v=fHaCl6OBNRQ&app=desktop
You keep posting about the same error but you never follow the instructions given nor give rich context. Has it worked before? What are the parameters? Are you sure all IGBT banks are ok?
