BMW Electric Rear Differential
ScottS
Post by ScottS »
Just came across this motor on eBay. Wasn't aware that there was a BMW Electric Diff like this. It's from a BMW 2 Series F45.
https://www.ebay.co.uk/itm/BMW-2-SERIES ... 3198741222
Can't find any information on the specs of these (aside from on Wikipedia, that they're a 65kW motor).
Does anyone know anything about these? Could be another good source of motor/diff combo.
Image from here: http://www.eurodiagnosta.pl/testujemy/a ... 225xe.html
Has thanked: 145 times
Been thanked: 368 times
Re: BMW Electric Rear Differential
It looks very similar to Outlander rear motor and diff. Power is also similar.
What is the nominal voltage of the system? I seem to recall BMW hybrids use 320V nominal.
Battery looks kinda small. Is it NiMh?
A
Filip
Post by Filip »
The battery is 292,8V nominal with 26Ah = 7613Wh. Lithium-ion. From 2020 I think I have read that the battery will increase to 10kWh within the same dimensions, I have not yet seen one though.
