I just bought a Mini Mainboard and ESP32 CAN Web Interface & datalogger - community edition. I thought I could communicate with the Mini Mainboard via ESP32 CAN, that's possible, right?
Does the Mini Mainboard need to be updated or does it come with software out of the box?
Because I'm only getting 'Communication problem between ESP and STM'
Is there anyone who can guide me? That makes me happy!
- manny
- Has thanked: 59 times
- Been thanked: 159 times
Re: Mini Mainboard and ESP32 CAN Web Interface
Try changing the node id to something and than back to 1.
Good luck
Good luck
- PSA battery (50kWh)
- Zombie VCU
- Been thanked: 1918 times
Also if you only have the two on the bus close the solder jumper on the ESP32 to enable the 120 Ohm termination
welcome to the club.
I had the same error . You can find my post under "user interface" the post "can communication"
