Toyota PRIUS W5 RESOLVER Settings problem
DIETZENBACH
Has thanked: 22 times
Post by DIETZENBACH »
Recently I started work on the Prius W5 gearmotor .The resolver socket on it , is without cabel conector.
I fixed some wires in the socket and tested the connections. Got 5pair readings as follows:
A-21,4 ohm B-27,4 ohm C- 12,2 ohm D-30,6 ohm E-23,1 Ohm
I presume the A+E readings to correspond to the Cos coils and the B+D readings to Sin coils, and C-reading to be exitation connections.
Now ,I don`t know how to connect the double Sin / Cos coils at first , parallel or in series and then, how to create a connection with them to the 3pins on the VCU (Pin1,2,3+4,5) .
Any suggestions and help are apreciated
