TL;DR what gets communicated between Zombieverter and simpbms? Does simpbms "know" when Zombieverter is in Driving or charging (via CAN) for the balancing to work (or not to work)?
Now for a little bit longer description, I will start by saying that english isn't my first language so excuse me if I don't find the right words (or technical terms), secondly I would like to thank everyone for their contribution to Zombieverter and Simpbms.
Now for the question, I don't have a full simpbms (hardware) setup, just a teensy 3.2 I found in my pile of electronics "junk" and a what-I-believe a compatible CAN Transciever, I have the teensy programed with BMWphevBMS hex for my SP41 bmw battery 12 kWh battery, I read enough to understand how to communicate with the battery slaves (5v, grd and CAN), my intention is battery monitoring and balancing and I can't seem to find if the SimpBMS will know the Zombieverter "mode" via CAN in the default simpbms configuration or if the only way is to have hardwire charge qnd drive with proper simpbms hardware.
Thanks again, I would appreciate any help
Edit: please tell me if this is the right forum or this should be moved to BMS.
