Gen3 PDM on Gen2 inverter with ZombieVerter.
GregFordyce
Has thanked: 25 times
Been thanked: 21 times
Post by GregFordyce »
I'm looking at options to upgrade the 3.6kW OBC in my full Gen2 stack with ZombieVerter. I know that a 6.6kW Gen2 PDM is a straight swap but they are difficult to find. Would it be possible to use a Gen3 or eNV200 PDM as most of those have a 6.6kW OBC?
Thanks in advance, Greg
Peugeot Expert LWB 2009
Zombieverter - Full 80kW Leaf stack
24kWh & 30kWh Leaf batteries in custom battery box under van
m.art.y
Has thanked: 37 times
Been thanked: 36 times
Re: Gen3 PDM on Gen2 inverter with ZombieVerter.
Post by m.art.y »
GregFordyce wrote: Sat Jul 05, 2025 8:34 am Would it be possible to use a Gen3 or eNV200 PDM as most of those have a 6.6kW OBC?
It would not be a straight swap into a gen2 Leaf as from what I heard chademo does not work but with Zombie it does not matter too much as you have the freedom to modify the wiring. So yes I think you could use it no problem but I think you would have to get it together with type2 socket to make it easier. Let me know if you're interested as I have them for sale. Also complete gen3 Leaf stacks for that matter. I know gen2 stuff is cheaper but then you have less power and more weight and then 6.6 kw PDMs are rare and expensive because Leaf drivers want them.
GregFordyce
Thanks m.art.y, I did think that as long as they bolt together the ZV would be okay with any PDM that it supports. Good point about the type 2 connector. Do you know if the round harness connector (F18) is the same on Gen2, Gen3 and eNV200? I'll keep you in mind if I do decide to change the PDM. Chademo should be fine as the ZV supports that directly, as I understand it.
