Hello!
I am a student in DCU and currently working on a project involving a Lexus GS450H Motor and its Inverter. I just bought the Zombieverter VCU Pre-Built kit and was wondering if I needed to buy extra connectors to connect The VCU to the inverter. For the inverter I have one already which is male, is the one that comes with the VCU also male or would I need to buy a female one? if so, which one is it?
Connectors for Zombieverter VCU
- robertwa
- Has thanked: 145 times
- Been thanked: 195 times
Re: Connectors for Zombieverter VCU
Suggest you spend a good bit of time on this page, reading and watching the video's, a lot of great content there.
https://openinverter.org/wiki/ZombieVerter_VCU
If you bought the 'fully built' VCU from EVBMW then it has the 56 pin header already soldered to the board. You will need the mating connector. A couple of options are listed on the page in the link above.
