Page 1 of 2
Yaris Gen4 iBooster Gen2
Posted: Sat Dec 28, 2024 1:31 pm
by itiuk
I'm starting this thread to share some information I've found specifically regarding the Gen2 iBooster found in the Gen4 Yaris, and the possibility of using this in homebrew applications.
For my own project, I'm taking the long approach to one day electrifying a 2003 Mazda MX5 (NB2.5). It's not my daily driver but I do want it off the road for as little time as possible. I'm therefore tackling as many small jobs as possible ahead of the conversion. One such job is deciding what to do about the factory vacuum brake booster. I don't like the idea of standalone vacuum pumps, and I'm not keen on de-assisting the brakes either, so the electric booster option is an option I want to explore.
Firstly, I did try a Gen1 iBooster from a Jaguar iPace, but the physical packaging just wasn't going to work in the end - too much interference with surrounding bodywork.
I ended up choosing the Gen2 iBooster from a Yaris firstly because the packaging more naturally suits the MX5 engine bay. The booster-bulkhead interface is also the same as MX5 factory (80x60 M8), so no adapter plate is required. The pushrod is also directly usable, albeit with a new clevis for the pedal (M8, short, trimmed slightly to allow use of a locking nut).
On the other side of the booster, things are slightly complicated by the master cylinder being clocked 22.5° (anticlockwise from vertical). The stock reservoir from the Yaris allows for this by having it's connection to the master cylinder clocked to match, but unfortunately this reservoir doesn't fit in the MX5. This part of the conversion is currently tbd.
For the master cylinder itself, I'm using a Bosch 0 204 854 799 (got mine from a Vauxhall/Opel Grandland X), which has a 1" bore vs the stock MX5 (Sport) 15/16" bore and with the outlet ports on the more favourable side to mimic stock MX5 packaging. The brake line connections are M12x1 DIN bubble flare on both ports. In an effort to minimise fabrication, I'm using the fact that the factory MX5 has a joint in the hardlines just before the reach the master cylinder. This means that the only custom brake lines I need are the two short runs from the master cylinder outlet ports to the factory joint (3/16 cunifer line with M12x1 DIN bubble on one end, M10x1 double inverted flare on the other, bent to suit).
I should also point out that I had to drill out the 8mm mounting holes on the master cylinder to 10mm. This is because this particular master cylinder has a mounting stud spacing of 102mm whereas the iBooster studs are 100mm spaced. This solves that problem, and since there is an additional mounting plate for the hardline, which will act as washers/spreaders for the stud nuts, I am comfortable with this mod.
More info and pics to follow shortly.
Chris
Re: Yaris Gen4 iBooster Gen2
Posted: Sat Dec 28, 2024 1:51 pm
by itiuk
Installed with a temporary remote reservoir (Honda CRV), although unfortunately I can't use a remote reservoir as there is no obvious space to mount one properly. I had to grind a very small amount of flange off the bottom of the iBooster to allow it to fit without fouling the bodywork.
Also you can see the hardline joint, the brass thing next to the master cylinder with the two factory lines connected to its top. The factory joint doesn't quite work in this application, so this brass block is a brake line joint from a Subaru Forester.
Better view of a small bracket used to mount the joint in the hardlines.
The trimmed M8 clevis joint.
Possible reservoir from a Mini R56, but requires an adapter to change the mounting angle. I'm awaiting a mock 3D print to test fit, but of course this would need to be something like machined aluminium to be properly functional.
Posted: Sat Dec 28, 2024 2:24 pm
by itiuk
On the wiring, after some searching and an eventual defeat by paywall, I have purchased the wiring manuals for the Yaris MK4. They reveal that the wiring is not the same on the Yaris as it is in other iBooster Gen2 applications.
Interestingly, there is a "Brake Control Power Module" (89680-K0010) which appears to be an emergency back-up power source for the iBooster in the event of power failure in the vehicle. I have not seen this in other conversions, but at £35 off fleabay I thought it would be something worth having. Currently awaiting delivery for test-fitting. This module connects to pin 17 on the iBooster (usually an unused pin on the Gen2, according to other guides) along with a few others (see pinouts below).
There are also connections to the door-open vanity light switches and to the stop light circuitry. Since I will be keeping the stock MX5's brake wiring with its pedal switch, I will probably not make any use of this.
It's also worth noting (as others have elsewhere) that the pedal travel sensor connector pins on the Yaris iBooster are in reversed order compared to normal.
Yaris iBooster Gen2
Connector: 82824-K0100
Bosch "EuCon" 26p
01: +12V 40A fused permanent live
02: Pedal Travel Sensor (pin 3)
03: -
04: CLIN (to pin 2 on BCPM)
05: -
06: -
07: -
08: Pedal Travel Sensor (pin 1)
09: GND
10: CAN1 L
11: -
12: -
13: -
14: -
15: CTY (door courtesy light switch)
16: CAN2 L
17: CBKP (to pin 6 on BCPM)
18: CAN1 H
19: -
20: IGR switched, 5A fused, hot in run/start
21: STP (stop light circuit)
22: Pedal Travel Sensor (pin 4)
23: Pedal Travel Sensor (pin 2)
24: CWKP (to pin 3 on BCPM)
25: CAN2 H
26: -
Pedal Travel Sensor
Connector: 82824-K0120
TE MQS (4 pin)
01: iBooster pin 8
02: iBooster pin 23
03: iBooster pin 2
04: iBooster pin 22
Brake Control Power Module (89680-K0010) (BCPM)
Connector: 90980-12785
01: +12V 10A fused permanent live
02: LIN (iBooster pin 4)
03: WKUP (iBooster pin 24)
04: GND
05: -
06: OUT (iBooster pin 17)
Posted: Sat Dec 28, 2024 3:19 pm
by itiuk
I need to put the wiring loom together and get the hardlines flared, then I will do some CANBUS sniffing and experimentation with the additional inputs and outputs, then I'll post an update :D
Posted: Sat Dec 28, 2024 7:05 pm
by manny
I am using the same ibooster from a yaris in my project. To get is to work in failsafe mode I needed to add 120 Ohm resistors to the CAN busses. And than power, ground and ignition.
Found the connector for the sensor on aliexpress
https://nl.aliexpress.com/item/1005004072725751.html
The connector is still on its way. So I am not a 100% that it will fitt.
Posted: Sat Dec 28, 2024 7:16 pm
by itiuk
Ah thanks for the hint. Were there any messages required to kick it into life, or simply the 120ohm termination?
I was lucky enough to receive the pedal position sensor connector (and it's mini-loom) with the iBooster when I bought it, but I've had to source the main connector and terminals/seals elsewhere.
Posted: Sat Dec 28, 2024 7:27 pm
by itiuk
Also, I've been wondering about this "failsafe" mode which is also mentioned. I understand that the theory is that if the CAN signals are absent, the unit will work in this "failsafe" mode, but from what I can tell, other than some diagnostics and the ability to remote-control the pedal, I'm not sure I understand what's really different. I imagine the calibration/assist curve is unchanged, and it's not running reduced power like certain electric power steering pumps do..?
Posted: Sat Dec 28, 2024 8:09 pm
by manny
itiuk wrote: Sat Dec 28, 2024 7:16 pm simply the 120ohm termination?
Yes, it sends canbus but it's not needed to received or answer.
itiuk wrote: Sat Dec 28, 2024 7:27 pm I imagine the calibration/assist curve is unchanged, and it's not running reduced power like certain electric power steering pumps do..?
Don't know about the power level. Assist curve and remote control of the brake can probably be controlled via CAN
Posted: Sat Dec 28, 2024 8:30 pm
by itiuk
Excellent, thanks.
manny wrote: Sat Dec 28, 2024 8:09 pmDon't know about the power level. Assist curve and remote control of the brake can probably be controlled via CAN
I'm hoping to be able to contribute on this one at least - part of my team at work handles ADAS simulation, so they are all over CAN signals and debugging. Hopefully I can get something useful from them :)
Posted: Wed Jan 01, 2025 3:08 pm
by itiuk
Update on the reservoir - after further browsing and googling, I've found that the reservoir from a VW Golf Mk7 or Passat B8 (LHD version) not only matches the clocking of the Yaris master cylinder, but fits the package space I have and has the fluid level sensor on the convenient side of the reservoir. The part number is 5QE611301.
All I need to do is find one... Since I live in the UK I need to search overseas for this reservoir. I've got leads on a couple but the postage is more than the cost of the item itself. :/ Will have to pull some strings with my EU-based colleagues at work.
Posted: Fri Jan 03, 2025 7:04 pm
by itiuk
I have received the Brake Control Power Module :D cute little thing that it is.
It's roughly 14 x 12 x 5 centimeters.
I've found a convenient place it, right next to the iBooster, tucked under the wing;
There are three less-than-perfect-but-probably-okay existing mounting points nearby, all on the main fusebox bracketry. I'm drafting up a cardboard template for the mounting plate as we speak.
I was careful to order one with the connector, here it is with pins half-way removed;
The connector is as follows;
Terminals;
Sumitomo TS sealed series
8100-0461 (0.5-1.25mm²) (3off)
8100-0462 (2mm² max) (2off)
Pinouts;
04: GND
05: -
I've bought new terminals and am just waiting for some new wiring to come through the post :)
Posted: Fri Jan 03, 2025 7:56 pm
by manny
Nice
Would be interesting to see the data on the linbus
Posted: Fri Jan 03, 2025 8:47 pm
by itiuk
I'll be sniffing LIN and WKUP as soon as possible - I'm intrigued. The +12V and GND are obvious of course, and OUT seems to be the line for providing working power to the iBooster in case of a power cut. The other two must be to do with identifying a power cut condition but I'm just guessing.
An internal wiring diagram would be useful, but I doubt I'll find one - these things are normally proprietary "black-boxes". At ~£30 a pop, I might buy a second one to tear apart if sniffing is unsuccessful.
Posted: Sat Jan 11, 2025 7:03 pm
by itiuk
A small amount of "exciting news";
I ended up buying a whole iBooster/master cylinder from Lithuania for ~£110 just for the reservoir :? At least I've got it now, and it fits like a glove in the car :D . I can also sell off the iBooster and reservoir-less master cylinder on the bay to make the money back.
As you can see, progress on the car has been nil since we've been snowed in. Tonight I worked up the bravery to break the ice to open the door in order to open the bonnet.
Also received the new wires today to make up the iBooster mini-loom. Just need to wait for the snow to melt a bit so I can get into my shed and retrieve my crimpers :lol:
I've also got as far as I can with the cardboard template for the power module bracket. I'm hoping it'll warm up a bit tomorrow so I can go out and draft it up in the car.
Posted: Thu Jan 16, 2025 6:33 pm
by manny
manny wrote: Sat Dec 28, 2024 7:05 pm The connector is still on its way. So I am not a 100% that it will fitt.
After 3 weeks of delay my package finally arrived. I can confirm that the connector fits fine.
parts
parts
wired connector
wired connector
on booster
on booster
Posted: Thu Mar 06, 2025 7:56 am
by Miata25
Hi Manny, (and Chris ;-)),
I stumbled across this post on my search about retrofitting an iBooster to my old Mazda MX-5 MK1/NA- I bought the same Yaris iBooster (though I bought an RHD one due to space restrains). The Yaris booster has the perfect fittment with the 80x60mm bold pattern for my car.
In the meantime I found a perfect fit master cylinder with reservoir - part.nr. is 3Q1614019D from a lot of newer VW/AUDI/SEAT/SKODA:
The new master cylinder is 23,81 mm bore and has two M12x1 double bubbled flare ports. The reservoir is tilted slightly sideways and gives it the correct orientation for my setup. The master cylinder has the same push rod measurements as the Yaris 22.2 bore cylinder- so I am going to use the VW one with adaptor brake lines M10x1 inverted flare on the Miata side - M12x1 double bubble flare on the master cylinder side, so I can use the Miata brake proportioning valve.
Do you already have the iBooster working in your car? What are your experiences, any problems with the clicking/ trying to calibrate?
Thanks and greets
Sven
Posted: Tue Mar 11, 2025 7:15 pm
by manny
Have the Ibooster installed in my car. Because of my car has drum brakes in the back, I ordered a set of Wilwood 10 psi residual valves. still waiting on Fittings :? . Without the residual valves I have to press the brake pedal to far for my liking. But it brakes well.
sometimes I can hear a click, but not really a problem. Will tray to preload the pedal a bit.
Posted: Tue Mar 11, 2025 10:27 pm
by jrbe
manny wrote: Tue Mar 11, 2025 7:15 pm Will tray to preload the pedal a bit.
This is a bad practice. As heat builds in the system the pressure also builds and the brakes will drag.
Make sure you got all the air or of the system. Sometimes there are bleeders at the master. You can crack the lines at the master too but it's messy. Pressure bleeders usually work well. Reverse bleeding can work well if you have air trapped that didn't work in the normal direction.
Posted: Thu Mar 13, 2025 10:16 pm
by itiuk
Bleeding the brakes is a job for me this weekend. I didn't bench-bleed my master and new lines, so there's a fair amount of air in there, but the plan was always to do a flush as it's been about ten years since the last brake fluid flush anyway.
No clicking from mine yet on power-up, but due to the air in the lines it's not fair to comment on actuation yet.
I'm also getting distracted by the other sub-projects on the car (E/HPAS, liquid cooled condenser, EV powertrain drafting). One thing which is taking a lot of my attention is the hunt for a cheap MX5 MK1 5spd gearbox (other forums are telling me I shouldn't be paying more than £30 for it...) for mocking up a motor interface.
Posted: Mon Apr 28, 2025 8:12 am
by Miata25
Did you manage to bleed the iBooster already? I suppose you have to switch the iBooster on, when doing this?
Posted: Mon Apr 28, 2025 6:21 pm
by manny
I got an adapter to put air pressure in to the brake fluid reservoir.
Put 0,5 to 1 bar of pressure in the reservoir. And than one by one open the bleed nippels.
Make sure you don't push all of the fluid out of the reservoir. If you do, you can start all over again. :?
Miata25 wrote: Mon Apr 28, 2025 8:12 am I suppose you have to switch the iBooster on, when doing this?
No does not matter. Even if you do it the old fashion way.
After adding the Wilwood 10 psi residual valves the breaks feel the same as in the gas Saxo I have.
Posted: Tue Apr 29, 2025 6:46 am
by Miata25
Yeah, I also just ordered an adapter for my pressure bleeder- so I can do it alone, I don't always have a second person to help...
Thanks for your heads up!
manny wrote: Mon Apr 28, 2025 6:21 pm I got an adapter to put air pressure in to the brake fluid reservoir.
Posted: Fri May 09, 2025 11:00 am
by marcexec
Thanks all for the effort! I have started collecting info on some versions of the iBoosters out there in a table to help people choose the best starting point, but measurements are important for that. Could you add the details to the Wiki page? I'm happy to help with editing!
https://openinverter.org/wiki/Bosch_iBooster
Posted: Fri May 09, 2025 1:17 pm
by Miata25
so just as of today I got the Yaris iBooster up and running in my MX-5.
ATM I am not entirely happy with the brake feel. The brake is stiff for a splitt second, then starts to go down to breaking point - I thought there should be more generic feel to the pedal. The breaking itself is sensational, I can get the NON-ABS car to lockup in a breeze... What bugs me is the artifical break feel.
Greets
Sven
Posted: Fri May 09, 2025 8:39 pm
by itiuk
Miata25 wrote: Fri May 09, 2025 1:17 pm Hi,
Greets
Sven
Are you running the additional BCPM?
In answer to Manny and maybe alluding to this issue, I have looked again at the wiring diagrams. I did wire my loom according to the Yaris diagrams, but didn't think too much into it, but the LINbus appears to be only between the iBooster and BCPM. Having connected them, I guess the required messages on LIN are satisfied, maybe this is a factor in why I'm not seeing the same issue in artificial pedal feel?
