Bosch iBooster
Jump to navigation
Jump to search
| Part number(s) | Vehicle(s) | Years | Generation | Firewall bolts (W×H), bolt ⌀ & cutout ID | L × W × H | Reservoir | BMC bore, brake line & threads | Notes |
| 5QE614105AH, 5QE614105AK, 5QE614105S | Volkswagen e-Golf | 2016 - 2018 | ||||||
| 5QE614105AH, 5QE614105AK, 5QE614105S | Audi A3 Sportback e-tron | 2017 | ||||||
| 5QE614105AK, 0204N01504, 0204N01963 | Volkswagen Passat GTE / Volkswagen Golf GTE / Golf MK8 | 2017 | Gen 1 | |||||
| 5QE614105AN, 5QE614105AQ, 5QE614105BA, 0204N00300 | Volkswagen e-Golf | 2018 - 2019 | Gen 2 | |||||
| 1037123-00-A, 1037123-00-B | Tesla Model S / Tesla Model X | Gen 1 | 72 × 72, 8.5 & 76.35mm | 320 × 155 × 215mm | 2x 26mm, M12x1, 6.25 mm | https://www.yourspec.com/bosch-ibooster-install-on-an-air-cooled-porsche-911-carrera-3-2/ | ||
| 1044671-00-D, 1044671-00-E, 1044671-99-F, (RHD)1044672-00-D | Tesla Model 3 / Tesla Model Y | 2017 - 2023 | Gen 2 | 74 × 66.5, ? & 72.5mm | ≈390 × 190 × 260mm | MC-mounted, staged front/rear | 26 mm, M12x1 (16 Nm), ~15 cm³ displacement | thread; bore/dims from evcreate.com. |
| Peugeot 3008 | Gen 2 | 72 × 72, ? & 72.5mm | ||||||
| 46000-TVA-A130-M1, 0204862292, 4600030AA04, 0204N02074, 46000TVAA32, 0204N00778 | Honda Accord | 2018 - 2021 | Gen 2 | 80 × 60, 9.5 & 76.35mm | OAL 251mm (155mm without MC) | OE reservoirs are tall (awkward for low remote mounting) | 25.5 mm, M12x1; ports 41 mm apart | thread; measurements from irate4x4: input 1.25" stroke + ¼" eyelet clevis, output 2× M12×1.0 bubble, clevis pin 11 mm / M10×1.5, mount-face-to-clevis 110 mm, cutout 62 mm. |
| 47210-02080, 47210-12591, 0204N02117 | Toyota Corolla Hybrid | 2023 - 2024 | Gen 2 | (rectangular pattern) | ||||
| 472106527R, 0204N00866, 0204N00212, 0204N00127 | Renault Zoe | 2013 - 2023 | Gen 2 | 72 x 72, m8x1.25 | 137mm x 245mm x 225mm (without master cylinder) | remote with flat mini reservoir | 2 x m12x1, 6.25mm brake line | master cylinder bolt spacing 99mm, requires connecting to a CAN network to operate (no Can messages required to be sent for failsafe mode, just CAN acknowledgement) |
| 46000TNYG030M1, 0204N00321 | Honda CR-V | 2020 - 2021 | Gen 2 | (rectangular pattern) | remote | ~15/16" (23.8 mm) unverified | ||
| 46000-TLC-A051, 0204N00081 | Honda CR-V | 2017 - 2019 | Gen 1 | (rectangular pattern) | remote | ~15/16" (23.8 mm) unverified | ||
| 26400VC011, 0204N01764 | Subaru WRX | 2022 | ||||||
| 26400AN09A, 0204N01279 | Subaru Outback & Subaru Legacy | 2023 - 2024 & 2023 | ||||||
| 460072682R, 0204N01444 | Renault Austral | |||||||
| 460078309R, 0204N01839 | Renault Megane E-Tech | 2023 | narrow | |||||
| 472107786R, 0204N00214 | Renault Arkana | 2021 - 2022 | 72 x 72, M8, | requires CAN (pins 16 & 25) network to operate: thread | ||||
| 47210-0D090, 0204N01926 | Toyota Yaris Gen 4 | 2020 - present | Gen 2 | 80 × 60, M8 & 76.4mm | 223mm, 134mm without MC | MC-mounted, angled at 22.5° anticlockwise from vertical (front view) | 22.2mm (7/8"), M12 inverted flare, 1/4 (6.35mm) line | thread. Needs control box (BCPM 89680-K0010) / LIN bus communication to power up: thread — will NOT run on power/gnd/ign alone. |
| 42761400, 42698897, 42576675, 0204N00947 | Chevrolet Bolt | 2019 - 2023 | 23 mm (needs verification), Bosch, M12x1.5 flare | [1] | ||||
| 84669159 | Chevrolet Volt | 2016-2017 | Gen 1 | M12×1.50 inverted flare ports |
(B)MC = (Brake) Master Cylinder
| Type | Donor (part no.) | Bore / size | Ports / threads | Fitment notes | Source / confidence |
| MC | Bosch 0 204 854 799 (Vauxhall/Opel Grandland X) | 1" (25.4 mm) | M12×1 DIN bubble ×2 | 102 mm studs (drill iBooster 8→10 mm); ports on favourable side for MX5 | openinverter [M] |
| MC | 3Q1614019D (VW/Audi/SEAT/Skoda) | 23.81 mm | M12×1 double-bubble ×2 | reservoir tilts to correct orientation; pushrod matches Yaris cyl | openinverter [M] |
| MC | Honda Accord (Gen2) | 25.5 mm | M12×1 | ports 41 mm apart; OAL 251 mm | irate4x4 [M] |
| MC | Tesla (Model S / 3) | 26 mm | M12×1 (16 Nm) | staged front/rear, ~15 cm³; 72 mm M8 mount | evcreate [M] |
| MC | Chevy Volt | not measured | M12×1.50 inverted flare | hard-to-source fittings | irate4x4 [M] |
| MC | Honda CR-V | ~15/16" (23.8 mm) | — | comes with donor | irate4x4 [R] |
| MC (bore ref) | Rivian R1T | 27 mm | — | bore reference only | irate4x4 [R] |
| MC (bore ref) | Lucid Air | 25 mm | — | bore reference only | irate4x4 [R] |
| MC (bore ref) | Chevy Bolt | 23 mm | M12×1.5 flare | bore reference only | irate4x4 [R] |
| Reservoir | VW Golf Mk7 / Passat B8 LHD (5QE611301) | — | — | matches Yaris MC clocking | openinverter [M] |
| Reservoir | Mini R56 | — | — | needs machined adapter for mount angle | openinverter [R] |
| Reservoir | Mini F56 / BMW F40 (0204794060) | — | — | compact alternative | evcreate [R] |
| Reservoir | Honda CR-V remote | — | — | level-sensor connector Sumitomo HX040, key 6189-0891 | evcreate [M] |
| Reservoir | Chevy Captiva 2012–2015 | — | — | floated as a reservoir donor | irate4x4 [?] |
| Reservoir | OE Honda Accord | — | — | tall — awkward for low remote mounting | irate4x4 [M] |
| Role | Part number(s) | Type / size | Terminals & seals | Fits | Notes |
| Main ECU connector (housing) | Bosch 1928405762; Toyota 82824-K0100; Tesla assy 1037271-00-A | EUCON, 26-way, female | Cavities: 22× BTC1.5 + 2× BTC2.8 + 2× BTC4.8 | Universal Bosch body; Toyota PN = Yaris | Same Bosch housing across donors. Toyota↔Bosch equivalence assumed (both EUCON 26-way), not cross-listed — verify. |
| ECU power / ground terminals (pins 1, 9) | Bosch 1928498807 (terminal); seal 1928301086 (Ø3.4–3.7) or 1928301695 (Ø4.0–4.5) | BTC 4.8 (4.8×0.8) | 2.5–4 mm² wire | All gens | Tesla uses 4 mm². Yaris AVS 3 (~3,3 mm²) |
| ECU medium terminal (Yaris pin 17 / Gen1 permanent 12V) | Bosch 1928498806 (terminal); seal 1928301206 (Ø2.0–2.7) or 1928301085 (Ø2.7–3.0) | BTL 2.8 | 1.5–2.5 mm² | Yaris Gen2 (pin 17 CBKP); Gen1 (permanent 12V) | Generic/Tesla Gen2 does NOT populate pin 17; Yaris does (CBKP→BCPM). Order by P/N (BTC/BTL share the 2.8 cavity). |
| ECU signal terminals (CAN, ignition, pedal sensor) | Bosch 1928498705 (0.35–0.5 mm²) or 1928498805 (0.5–1.0 mm²); seal 1928301118 / 1928301083 (Ø1.6–1.9) / 1928301084 (Ø1.9–2.1) | BTC 1.5 (1.5×0.6) | 0.35–1.0 mm² | All gens | Choose seal by wire OD. |
| Pedal travel sensor connector | Toyota 82824-K0120; aftermarket AliExpress 1005004072725751 | TE MQS, 4-way | (sensor integral to booster) | Gen1 vs Gen2 differ by this connector's housing/pin numbering — the defining visual difference between generations. | |
| BCPM connector (Yaris companion module) | Toyota 90980-12785 | 6-way sealed | Sumitomo TS 8100-0461 ×3 (0.5–1.25 mm²); 8100-0462 ×2 (≤2 mm²) | Yaris BCPM 89680-K0010 | Yaris-specific. Supercap buffer supply; the booster needs LIN comms to it to run. |
Sources:
- EV Conversion Parts#iBooster Sourcing
- https://www.evcreate.com/ibooster-donor-vehicles/
- https://www.evcreate.com/installing-the-ibooster/
- https://openinverter.org/forum/viewtopic.php?t=5925 (Yaris)
- https://irate4x4.com/threads/ibooster-electric-brake-booster.394316/ (master-cylinder & dimension data)
