With all the awesome projects here, I am starting a project to just learn before diving fully in.
I found a good price leaf inverter gen 1 (291a0 3na0a) ebay that is on it way, my goal would be to learn how to control the inverter before i buy a motor.
I plan on is using a laptop power adapter to supply the 12v. And a voltage power supply for the HV. I am assuming that there are tests that can be done with a multimeter to see if things are running correctly before connecting to a motor.
As I understand it there is a logic board that is used with the inverter to control it. But when I click the link in the github
https://github.com/damienmaguire/Nissan ... me-ov-file
I no longer see it available. Is that correct?
Thanks,
Rick
