Nissan Leaf 2018+ VCM from Damien Maguire
Paerel
Post by Paerel »
Hi, does anyone try to use Damien's board or any others to run Nissan Leaf 2018+ ?
Been thanked: 1136 times
Re: Nissan Leaf 2018+ VCM from Damien Maguire
No. As I have not had access to a 2018 or newer car I don't have any information on how to run this as yet.
Kelju
Has thanked: 13 times
Been thanked: 19 times
Post by Kelju »
Bringing an old topic to surface.
I have a 2018 Leaf Gen3 inverter and I am currently trying to get it running with the Johannes V3 mainboard.
I am also thinking about having a look into direct CAN control of the OEM board.
Is the CAN database the same for gen1 and gen2 Leaf inverters?
If so, this would suggest that it might be the same also for the gen3...
celeron55
Has thanked: 39 times
Been thanked: 136 times
Post by celeron55 »
Kelju wrote: Sat Nov 07, 2020 2:45 pm Is the CAN database the same for gen1 and gen2 Leaf inverters?
There are minor differences in the protocol between gen1 and gen2. If you're lucky it might accept the gen2 protocol. If it doesn't work you will have do a CANbus capture from a gen3 Leaf as we don't have the data.
