Hello I’ve been reading and looking around for a while now although haven’t seen any clear info on a few things.
1. Is the PDM needed to run the inverter and motor? I plan to use the leaf motor only as a on demand boost and use the factory installed ice engine to regen and charge the batteries.
2. Is there a maximum amperage the leaf system can be ran at? I’d be looking at around 640 amps using a 250v LTO battery pack and the160kw inverter
Nissan leaf stack and amperage
- Has thanked: 393 times
- Been thanked: 111 times
Re: Nissan leaf stack and amperage
1. No the pdm is not needed for operation
2. No idea on max Amps. I've seen the leaf em61 motor and a custom inverter running 400hp.
Thank you!Jacobsmess wrote: ↑Fri Oct 18, 2024 6:32 am 1. No the pdm is not needed fir operation
