LDU parameters to reduce power
sirpewe
Post by sirpewe »
Hi.
Can someone please guide me a bit how I can change parameters to decrease power output?
My first idea was to use the current limit but this seems to set the inverter/motor in error state if triggered?
I would like to have the possibility to adjust the power output in a controlled way.
// Per
Has thanked: 330 times
Been thanked: 848 times
Re: LDU parameters to reduce power
throtmax, you can reduce it to limit max requested throttle which reduces power.
Has thanked: 323 times
Been thanked: 352 times
Post by P.S.Mangelsdorf »
fslipmax also seems to reduce power. I'd check out the parameters threads and basically do the opposite of everyone raising power levels.
Boxster EV
Has thanked: 57 times
Been thanked: 50 times
Post by Boxster EV »
In the past when I’ve had OC events doing hard pulls (usually occurs during wheel hop), it’s fslipmax that I’ve backed off.
Not had one now in a few years. However, the firmware version can have a big influence too. I recently upgraded from 5.20 to 5.35 and the latter made the car a lot more powerful, even with an identical parameter file.
sirpewe
Post by sirpewe »
Thank you all very much for the input.
tom91: I like the simplicity in this approach. I plan to send some can messages to be able to set different "power levels" and this should be easy.
Others: Will check parameters more for tuning. :)
