Foccci CCS2/OBC/Orion BMS wiring diagram
Posted: Wed Jun 05, 2024 5:30 am
by PoloLbricolo
Hello,
I'm planing the integration of the focci module in one of my conversions.
I wasn't able to find a wiring diagram so I made one, if those who have integrated it could correct me if need be, i'll make the updates so it can be usefull for others.
Focci board 4.5a as it is what I have.
Re: Focci CCS2/OBC/Orion BMS wiring diagram
Posted: Wed Jun 05, 2024 6:12 am
by uhi22
This looks good, the only remark from my side is the grounding. I would not route the ground via the Foccci connector, but instead:
- wire the ground for the contactors to a "power ground" point which has a solid connection to battery minus. Do not route this contactor current over the ground of Foccci, because the relative high current (some amps) would lead to a ground shift between Foccci and chassis, which would disturb the analog measurement of CP and PP.
- wire the ground of the charge port temperature sensors directly to Foccci, because this is a sensitive analog measurement ground.
- wire the PE of the charge port to a good chassis ground (this is a path which shall be able to carry some hundred amps in case of a AC-to-chassis shortcut)
- Get the ground for Foccci from the same chassis ground point where the PE is mounted, because the PE is the reference for the CP and PP analog signals, so we do not want ground shifts there.
Posted: Thu Jun 06, 2024 5:46 am
by PoloLbricolo
Updated taking your advice.
I've added a PDF version as well.
Posted: Thu Jun 06, 2024 7:47 am
by uhi22
Looks good. For the wakeup line I cannot decide, I have no clue what the BMS and OBC expect or provide at this line.
Posted: Thu Jun 06, 2024 9:31 am
by PoloLbricolo
for the wakeup,
The orion bms expect a 12v when the plug is inserted/ when the bms needs to send the charge commands.
The OBC sends a 12V when the AC is applied.
Posted: Mon Jun 10, 2024 7:21 am
by MoonUnit
Thanks for your pdf.
Are you planning to run both AC and DC charging via the same charge inlet using the Orion?
Posted: Wed Jun 12, 2024 5:21 am
by PoloLbricolo
Yes, AC and DC charging. AC monophase 6.6kW
Posted: Wed Jun 12, 2024 1:47 pm
by MoonUnit
PoloLbricolo wrote: ↑Wed Jun 12, 2024 5:21 am
You might want to have a look at this thread
viewtopic.php?t=4746.
Re: Foccci CCS2/OBC/Orion BMS wiring diagram
Posted: Fri Jun 28, 2024 6:11 am
by PoloLbricolo
I confirmed that this schematic works. Charged in CCS2 yesterday.
Posted: Fri Jun 28, 2024 8:19 am
Posted: Sun Oct 19, 2025 10:07 am
by MoonUnit
PoloLbricolo wrote: ↑Fri Jun 28, 2024 6:11 am
Hi - did you manage to get AC charging working as well as CCS with Orion and Foccci?
Posted: Sun Oct 26, 2025 8:24 am
by joeflickers
MoonUnit wrote: ↑Sun Oct 19, 2025 10:07 am
awsome,how is your bms profile setup? I have a similar setup
