How to prevent motor rotation on zombie
evMacGyver
Has thanked: 73 times
Been thanked: 11 times
Post by evMacGyver »
Need to prevent motor rotation when driver door is open, what would be correct way to do this?
Door status is read from CAN and if I change throtmax on vehicle code, it would require trigger Param::Change(Param::PARAM_NUM paramNum), or change some parameter from webui.
Not the best way to (mis)use some vehicle function, like GetGear which is not used in my case.
J0hannes
Has thanked: 21 times
Been thanked: 182 times
Re: How to prevent motor rotation on zombie
Post by J0hannes »
Thinking out loud, this may have some drawbacks.
Why not have the door switch cut off 12V supply for the drive direction selection if you use switches?
Door open —> vehicle goes in to neutral.
J0hannes
Post by J0hannes »
Looking at the modification rules again, looks like I may need to figure out a solution to this one also😁
Maybe I'll just use the brake in signal in Zombieverter, that blocks throttle command. At least it should...
Then again for a pre October 2002 it says that driver needs to be notified when exiting, if the vehicle is in a mode which enabled active driving. --> Buzzer or a flashing light maybe🤔
https://www.finlex.fi/fi/viranomaiset/n ... 4001/46612
