Zombie gives no power to Inverter pin Topic is solved
JappeEs
Has thanked: 8 times
Post by JappeEs »
Hi and please help
I'm trying to set up the GS450H to test it. I have updated to version 2.15.A and I do get the Zombie in to Run mode but I don't get any power on pin 32 (Inverter Power LS switch).
I understand that pin is to connect to a relay for power Inverter and the relay for the oil pump.
Any special settings for this?
Grateful for any help.
Has thanked: 330 times
Been thanked: 848 times
Re: Zombie gives no power to Inverter pin
It is a LS (low side) or a pull to ground pin.
So you need to wire it as such, 12V to the relay other side to the pin.
JappeEs
Post by JappeEs »
tom91 wrote: Sun May 05, 2024 12:49 pm It is a LS (low side) or a pull to ground pin.
Thank you. That made a big difference :)
It works now. Just need to get an accelerator pedal to run it now :)
