Model 3 EVBMW PCS Controller support question
RhodieRuss
Post by RhodieRuss »
I have one of the EVBMW V3 PCS controllers. I have yet to power it up and test it, I am still trying to locate components to properly connect it to the PCS.
But I have a question regarding the Output 1 & 2 and input 1 & 2 pins 3,4,5 & 6
Can these outputs be used to control a coolant pump and cooling fan and the inputs use data from temperatures snensor in the cooling circuit to control the outputs?
Thanks for your time to read this.
Has thanked: 323 times
Been thanked: 352 times
Re: Model 3 EVBMW PCS Controller support question
Post by P.S.Mangelsdorf »
I don't recall off the top of my head what outputs 1&2 are used for, but I know Inputs 1&2 are used to tell the controller what mode to go into. If I remember correctly 1 is charge and 2 is drive. I know its covered in the development/closed support thread.
