1. Have Linux installed on your PC
2. Put inverter.zip in your desktop
3. Open xterm or applicable console
4. enter command "sudo apt-get install php5-cli"
5. then "sudo usermod -G dialout www-data"
6. and restart service by typing "sudo service apache2 restart"
7. unzip inverter.zip to desktop, all folders on desktop
8. connect USB to Serial adapter
9. in c type: "cd tools/web\ interface"
10. then type "sudo php -Slocalhost:8000"
11. Open your browser and type localhost:8000
Now enter your parameters and play with inverter. After every changed parameter you have to press enter for change to take effect.
HOW TO: Install web interface to Linux PC
- Been thanked: 1913 times
Re: HOW TO: Install web interface to Linux PC
Yery good!
You don't even need apache (step 6) as the php executable serves the site directly
- Has thanked: 166 times
- Been thanked: 411 times
Yes but I was using Lubuntu and I think there apache service is not started by default. I just added it so no one would be for worse by this procedure.
What I meant is that you don't need apache (or any web server) at all. "php -S" IS the web server
