EV conversion parts for sale in the UK
Peter
Been thanked: 9 times
Post by Peter »
Hi Forum. I have run out of time to finish my latest conversion so looking to sell as parts to forum members.
Tesla Model X P100D 2018 SDU from my last running conversion (Smart 450). Complete with bespoke oil/coolant heat exchanger with 12v external elec pump and filter. (Motor was run in reverse in Smart 450) Hydraulic hoses fitted to suit exchanger.
Battery box (Stainless !) with contactors fitted and charger. Battery is 10 x Volvo 66v @30Ahr = 330v @ 60Ahr.
HV wiring with plugs to go with package. SDU plugs with package.
HV powered heater, HV cables, charging cable with socket, coolant pump, oil pump, radiators with fans.
Pics provided if you let me know what is of interest
Will consider any sensible offers :-)
Thanks in advance. Peter
Has thanked: 545 times
Been thanked: 153 times
Re: EV conversion parts for sale in the UK
Post by Jacobsmess »
Hi Peter, are you looking to sell as a whole or would you be willing to split?
Peter
Post by Peter »
Hi Jacobsmess. Thank you for contacting me.
What are you interested in please?
Peter wrote: Mon Jan 15, 2024 10:10 pm HV wiring with plugs to go with package......
HV powered heater, HV cables, charging cable with socket, coolant pump, radiators with fans.
Any of the above... Pics appreciated and your rough location cheers
Peter
Post by Peter »
Based North West Lancashire, where are you ?
Coolant Pump 12v
Coolant Pump 12v
Rad + 12v fans
Rad + 12v fans
Vac Pump 12v
Vac Pump 12v
HV powered heater
HV powered heater
HV Cable 3.5M + HV Plug
nkiernan
Has thanked: 516 times
Been thanked: 95 times
Post by nkiernan »
What size cable is the HV cable (cross section and length) and what is the plug part number (to see if it fits the sockets I have already)
Peter
Post by Peter »
Hi nkiernan.
35mm cable, 3.5M length, joint at 2M from plug.
Plug number, 9-2141147-1
ZSB -2141154
Cable and plug pre-assembled 2M length2177201-8 TE HV
nkiernan
Post by nkiernan »
Thanks, was hoping it was larger cross section to suit my need
