During testing I discovered I have approx 70V to 76V between the live terminal of the HV battery connection in my HV junction box and chassis ground.
If I connect between the HV Pos and chassis ground using a 180R 1/4W resistor (so it would pop if there was a real short) The voltage goes to 0V with no current I can measure. When I disconnect the resistor the voltage immediately jumps to 70V then creeps up slowly
I see the same voltage at all times whether the rear battery pack is disconnected or not
It also shows whether all 12V connections are connected or not.
In my setup I have 40 cells in the front of the car so approx 160V and 56 in the rear with the pack positive going from the rear to the front battery box and the pack neg from the rear going directly to the HV junction box.
Any suggestions what is causing it, should I be concerned and could it mess up the VCU coms to the inverter?
Could it be capacitance?
Any help gratefully received thanks
