Multiple battery packs
FFMan
Has thanked: 8 times
Been thanked: 47 times
Post by FFMan »
I'm just planning the addition of a 12kwh pack to augment my current 9kwh pack.
the obvious approach is just to join the 360v outputs and run them in parallel, which i think is fine but i was wondering is it safe to leave them joined in this manner long term. If i have contractors to separate them, there is a high likelihood they will drop back at slightly different rates and that there will be a voltage difference when i come to join them again.
They need to be joined for charging and driving so it most useful to treat them as one pack but i wondered what others have done ?
E46 touring
BMW 9kwh & 12kwh packs
Has thanked: 206 times
Been thanked: 563 times
Re: Multiple battery packs
For a project I have them Parallel them at module level.
However I have a feeling your are missing a big big detail.
BMW PHEV, 9kWh gen 2 pack is 5 modules, 80 cells in series.
BMW PHEV, 9kWh gen 2 pack is 6 modules, 96 cells in series.
Connecting these together is a big bang.
FFMan
Post by FFMan »
tom91 wrote: Fri Aug 25, 2023 3:53 pm For a project I have them Parallel them at module level.
just checking before i set off on along trip to get the second pack tomorrow.
My current 9kwh pack is 6 modules, 360v
The new 12kwh pack is also 360v in 6 modules just larger capacity cells is it not ?
i.e. current pack and proposed pack are 360v.
E46 touring
Oh okay then it is a Gen1 pack. If both are 6 modules then the voltages will line up.
