Regen ramping
FFMan
Has thanked: 9 times
Been thanked: 50 times
Regen ramping
Post by FFMan »
I've been playing the regen settings to try and achieve strong but smooth regen. I have the brake pedal set so the regen cuts in at the very top of the pedal travel before any mechanical brake is applied.
It seems that the first time i hit the brakes the ramp up is working, but if i come off the brake and reapply within a seconds or so, the cut it is not so smooth. This might be just a perception thing and the lesson is pick your braking spot and not dab on/off, which will come in time i'm sure.
janosch
Has thanked: 98 times
Been thanked: 106 times
Re: Regen ramping
Post by janosch »
Can you do some plotting similar to what I did here and post them?
a plot with potnom, idc and brake_in would be very interesting
viewtopic.php?t=2141
