I'm getting started with the Nissan Leaf motor.
Are there specs available for things like Rs, Ls, Flux, Back EMF constant, power factor, efficiency, etc.?
I've looked through the resources here, but so far have not found them. I found on one page "openinverter rev3 board pre programmed with leaf motor tune", and maybe the tune has the info, but I'm not sure where to get that to check it out.
Thanks!
Nissan Leaf Motor Specs for FOC
- Has thanked: 102 times
- Been thanked: 350 times
Re: Nissan Leaf Motor Specs for FOC
Can't help with all of those but you can find some of them here https://openinverter.org/forum/viewto ... #p52763
Thank you!
That should be useful.
Also, the motor inertia is another spec that I am searching for.
