Posible bug with Terminal::KeyPressed()
Pete9008
Has thanked: 102 times
Been thanked: 351 times
Post by Pete9008 »
Been trying to use Terminal::KeyPressed() to terminate logging but couldn't get it to work (only worked occasionally). It turns out that the UART Rx DMA was still active in the background and grabbing the characters out the UART buffer and clearing the flag before KeyPressed saw it. Might be an issue in other places that the function is used too??
I've added a public Terminal::GetRxNumBytesAvail() function that returns the number of bytes in the DMA buffer and look for a change in value instead.
Been thanked: 1913 times
Re: Posible bug with Terminal::KeyPressed()
Yes, I noticed this as well and fixed it but never published it :(
I think I just checked for bytes in DMA buffer as well and returned true if >0
