Hi guys
I have the gigavac gv242mab contractors and resistors.
What do the red, black, white and blue wires do?
Does anyone have a precharge and HV circuit we can follow?
Precharge and HV circuit
- Has thanked: 166 times
- Been thanked: 411 times
Re: Precharge and HV circuit
There it is explained....
https://www.evcreate.nl/shop/charging/g ... contactor/
Both wires leed to coils. One pair is for hard turnon and the other pair is for holding.
- Has thanked: 91 times
- Been thanked: 517 times
Isn't one pair the low voltage auxiliary contacts?
"This is a new old stock Gigavac GV242MAB side mount contactor with normally open auxiliary contacts. It has a rating of 400+ A and max. rated voltage of 800VDC."
Well in any case i suggest you check them with a light bulb in circuit.
