I’m looking for the cv joint that goes into the Tesla drive unit. Model s/x
I don’t need the whole axle, just the inner joint.
Also looking for a spider gear from the differential with the female matting spline as well.
I will use these to design drive shaft stubs for the Tesla drive units.
unlike the ones from ev west or zero ev they will have the beetle 33spline so 90mm, 100mm and 108mm (930) flanges will work. They will also be much cheaper than what is currently available !
Wanted: Tesla inner drive shaft cv joint
- Bratitude
- Has thanked: 180 times
- Been thanked: 370 times
