i want to make my peugeot 407 on electricity, i will use rear axle from peugeot 508 hybrid (they are the some). The rear axle from 508 is with Bosch SMG 180/120 motor with resolver. I can't find good controller on right price. I will use on 144V peak 200A (27kw), continues 80A (11 kw) that is original parameters from manufacture. I read many information but not find the correct one... I can use sensorless controller but not will be smooth machine. i need only 2500-2900 RMP. Can i use inverter from Toyota Prius Gen2 G9200 - 47121 2004-2009 and https://openinverter.org/shop/index.php ... duct_id=63 ? my battery pack is 144V not need more. Or can i install https://openinverter.org/wiki/images/d/ ... ncoder.jpg to use with normal controller?
Thank you
Peugeot 407 hybrid
bliznakavd
- Has thanked: 12 times
- Been thanked: 9 times
