Golf Cart with bluepill
madius
Has thanked: 13 times
Post by madius »
Hi!
I am repairing a golf cart brushless motor controller with dead microcontroller.
My solution is openinverter!
I have a bluepill and all hardware of original controller its working.
My experience with openinverter its on a full STM32 dedicated board.
Is there a precompiled firm for bluepill?
I am using PriusG2_V1 as a reference for connecting all ports.
I see that some ports on that project has differences with standar openinverter.
Original motor controller is ACD4805 with vector control operation.
Any comments or suggestions are apreciated.
Has thanked: 462 times
Been thanked: 1784 times
Re: Golf Cart with bluepill
The standard firmware will detect that it's running on a blue pill and change the pinmap accordingly
https://openinverter.org/forum/viewtopic.php?t=220 (please read to the end)
madius
Post by madius »
johu wrote: Mon Nov 28, 2022 10:12 pm The standard firmware will detect that it's running on a blue pill and change the pinmap accordingly
Thank you johu,
I already have it running with firm V5.20.R-2 (it is the latest version with "sine" precompiled on github).
All the inputs work as well as the outputs, what I can't get the PWM outputs to work.
Is this procedure still valid for these last firmware versions?
start 2
This will start sine wave generation. Type
set fslipspnt 1
set ampnom 1
This outputs a clean 50/50 duty cycle on all 6 PWM outputs.
It's from:
https://openinverter.org/wiki/Schematic ... structions
thanks!
