Nissan leaf gen2 inverter run using can bus
Dennad
Has thanked: 4 times
Post by Dennad »
Hello everyone, I want to run the inverter from nissan leaf on the can bus without altering the inverter itself and use it to run the rear motor from the lexus rx400h, will this work? Or it works only with Nissan leaf motor?
Has thanked: 246 times
Been thanked: 469 times
Re: Nissan leaf gen2 inverter run using can bus
Dennad wrote: Thu Oct 27, 2022 10:12 am Hello everyone, I want to run the inverter from nissan leaf on the can bus without altering the inverter itself and use it to run the rear motor from the lexus rx400h, will this work? Or it works only with Nissan leaf motor?
nope!
inverters are tuned for the motor. in this case the leaf inverter still thinks its driving a leaf motor.
Dennad
Post by Dennad »
thanks for the information
