I'm set to buy an env200 on tuesday, 30th august 2022, next week. its has 80%soh and its a 24kwh. have about 6mths to sell my ze0 2011 muxsan after this and get the env200 capable of carrying the family, i.e. fit a rock and roll bed/seat
I plan to upgrade the battery to 40kwh but unfortunately 40kwh batteries are very thin on the ground. a few questions.
1) anyone have a spare working 40kwh env200 bms for sale?
2) are the internal bms wiring pinouts and battery locations similar between a 24kwh env200 bms and the 40kwh bms the same?
3) are leaf 40kwh cells similar to env200 40kwh cells?
4) any other suggestions to upgrading a 24kwh env200 in absence of a 40kwh pack
5) is the leaf bms similar hardware and can it be flashed into an env200 one?
I narrowly missed the boat on a 40kwh pack and I will obviously be looking out for one but I also think that it might be feasible to do a brute force upgrade in the absence of any whole packs for sale.
I did do some searching but came up with nothing yet.
E-nv200 24kwh to 40kwh upgrade
- Has thanked: 134 times
- Been thanked: 335 times
Re: E-nv200 24kwh to 40kwh upgrade
You could get yourself additional project (headache) by buying Kona or Ioniq battery and rewire the NV/Leaf BMS to it. BMS isnt picky which cells there are as long as its similar chemistry...whereswally606 wrote: ↑Sat Aug 27, 2022 4:48 pm I'm set to buy an env200 on tuesday, 30th august 2022, next week. its has 80%soh and its a 24kwh. have about 6mths to sell my ze0 2011 muxsan after this and get the env200 capable of carrying the family, i.e. fit a rock and roll bed/seat
that is more headache, also how do you confirm they are similar chemistry and then also fitment into the case and also water cooling etc etc.
- EV_Builder
- Been thanked: 37 times
Try muxsan in the Netherlands they upgrade this van if I'm right.
