when using the boost charger with openinverter v2 ( https://openinverter.org/wiki/Battery_Charging )
Why do you connect the (+) output of the charge rectifier to one of the motor phases, and not to the (+) rail of the IGBT's?
charging question with openinverter
- Has thanked: 380 times
- Been thanked: 1564 times
Re: charging question with openinverter
because then, how would you boost? Boosting implies you need an inductor that can be paralleled to the input voltage
https://en.wikipedia.org/wiki/Boost_converter
