Please could someone confirm how Openinverter's CAN IO function interacts with physical inputs?
Are they simply OR'd together, or is CAN able to override the physical input?
CAN IO interaction with physical IO
- Has thanked: 266 times
- Been thanked: 724 times
Re: CAN IO interaction with physical IO
Correct it is or'ed I checked as had a setup running.
Also configuration of IO for can bus settings is explained here: https://openinverter.org/wiki/CAN_communication
- catphish
- Has thanked: 99 times
- Been thanked: 195 times
Thanks, I read that and believe I understand how to use it. It implied that they must be OR'd (because it seems you inject zeros for ports that are still going to be physical), but wanted to double check.tom91 wrote: ↑Sun May 29, 2022 8:33 pm Correct it is or'ed I checked as had a setup running.
My car has a big button in the middle of the dash, my intention is to use it as both a start button and a cruise control button (depending on inverter state).
