I used the search function to find this out and I'm just not a hundred percent sure, so before I start cutting and welding the subframe for the motor I'd like to ask:
Does it matter in which direction i mount the motors?
In an AWD setup, can the front motor be mounted forward and the rear motor be mounted backwards?
Do both work same in Regen mode? It all i need to do negate the torque signal for the front motor?
Thanks, Philip
Can the rear outlander PHEV motor be mounted in any direction?
- Has thanked: 330 times
- Been thanked: 848 times
Re: Can the rear outlander PHEV motor be mounted in any direction?
Currently from testing there seems to be no limit in rotation speed, torque command limit in "forward" or "reverse" I have not yet tested
