Searched but didnt find anything. Anyone working on what is needed to get the charger and stock bms functional?
If not what is a doable alternative charger and bms for a prius prime 96s 350vdc battery.
Also whete would you hook up the prius prime battery output to a gen 3 2010 prius inverter? Stock location or the location bypassing the buck/boost converter. Asuming 2010 inverter will need resistors changed for the higher voltage prius prime pack.
Prius prime charger and bms
slociviccoupe
- Been thanked: 1918 times
Re: Prius prime charger and bms
Check the Audi videos on my channel (down below). Should get you a step further
