Newbie post: 2018 Rav4 MGR, Toyota inverter, used as a KERS system on the front axle of an MR2, with an ICE at the rear
Posted: Wed Dec 01, 2021 1:29 am
Hi everyone. I never know that you all existed until the other day.
A little about myself:
I'm a former Toyota Master Diagnostic Technician from a local dealership, who left that industry to go work for my public water utility in the instrumentation dept.
I currently program RTU's for the control and operation of across-the-line and VFD control of 3ph 480V (or a few 260V) motor and pump modules.
I also currently am an Adjunct Professor at my local community college teaching automotive and currently teaching Hybrid, Electric, and alternative fuels as a course.
Here's the story on my projects:
I own a 1991 Toyota MR2 with a 3.5L V6 engine swap from a 2007 Rav4 installed.
Ever since the Toyota Highlander HV was released, I have dreamed of installing that power train in reverse in an MR2. The downfall was that with Toyota's factory inverter, I would have ended up with rear axle regenerative braking. And in a vehicle with the engine weight in the middle-back, that's not a good idea.
SO! My brain never let things go, and here we are on the next iteration of ideas. What if I just took the MGR from a rav4 HV and placed it on my front axle as a supplement source of power? AND a way to recover some kinetic energy to help charge the batteries? like an F1 KERS system.
Like I said, up till I started looking for a video on R&R hybrid powertrains to show my students, I never knew this community existed.
What do you guys think of the possibility of using one of the smaller and more compact Toyota inverter assemblies to run a single motor/generator I/O?
Maybe using the second MG circuit for plug-in charging?
And pairing it with a modified Highlander HV battery pack where I can place half the batteries behind each seat, and exhaust the battery heat to the outside air ducts?
What controllers are you guys using for battery management ECU's?
I see some interesting info on custom logic boards for Prius inverters. (I haven't had a chance to do a deep dive yet on this)
How would you tie the logic board info in to the CANBUS and share info with my existing 2007 Rav4 V6 ICE? (throttle position,brake pedal, and clutch pedal status)
Side-note:
My MR2 does not have ABS, and as such, does not use any of the modern ABS/TRAC/EBD systems where I could share that CAN info.
My VSS comes from a 2001 electronic speed sensor mounted to the transmission. It spits out a digital signal in relation to vehicle speed, sends it to my instrumentation cluster, and the cluster sends back a signal that seems to keep the 2007 rav4 ECU happy.
In factory form, the ECU is looking for a VSS signal from the ABS module.
Side-note:
