Anyone has service disconnect from EV that has at least 400A capacity? I would need one to quickly disconnect my pack if i want to service something on HV side. The way i use my setup now it is quite cubersome to remove my 400A fuse and split the pack. Quick disconnect would help a lot.
TNX
400A+ service disconnect wanted
- jnsaff
- Has thanked: 3 times
- Been thanked: 8 times
Re: 400A+ service disconnect wanted
Why not use a contactor to always split the pack when HV is off?
- Has thanked: 134 times
- Been thanked: 339 times
No no procedure because that could cause harm on components (inverter, charger, dcdc) if DC link would be disconnected while driving. Just dont go there.
EDIT: i feel it neccessary to explain. My pack is actually two packs and in between them i have 400A fuse on positive side. If i wanted to service the pack i need to split it by removing the fuse. It would be easier to just pull the plug from the negative side and service the pack that way.
I am ME and i trust mechanical solution.
- Has thanked: 35 times
- Been thanked: 33 times
Thanks for giving us tips on those things, very useful. But we still need contactors to enable HV to the inverter and the rest of the system? Isn't it a similar risk? Your HV also isn't permanently connected to inverter and dcdc, is it?
Valid point. But my DCDC and chargers ARE permanently connected to battery via 30A fuses. Contactor only brakes complete link from battery box to inverter not the middle of the battery. So i have to split it manually.
I guess if you would have 2x contactors you could disconnect middle of the pack on the + side and - side of complete battery. That way you would split the pack to two packs and separate them from inverter. Ideally you would need 3x contactors for the best effect but they dont grow on trees
I need something easier to take apart than bolted fuse...
