Tesla front SDU oil - Mobil SHC 629 alternatives  [SOLVED]
catphish
Has thanked: 98 times
Been thanked: 195 times
Post by catphish »
I have a Tesla front SDU part number 1035000-00-F. It has no oil in it, so I need to buy some.
The information available states: Front drive unit part number 1035000-00-F and earlier: Mobil SHC 629
Unfortunately, I can't buy Mobil SHC 629 in the UK (at least in sane quantities). Would anyone be able to recommend alternatives?
My research into SHC 629 suggests that it's a fully synthetic industrial gear oil, ISO 150 with "EP" additives. I found this product, which appears to be the same grade: https://www.smithandallan.com/documents ... 20Oils.pdf
Would this be suitable? Are there any particular properties of SHC 629 that I need to be careful to match, or is there anything else in particular that people use for this gearbox?
Thanks!
EV_Builder
Re: Tesla front SDU oil - Mobil SHC 629 alternatives
Post by EV_Builder »
Isn't dextron IV ATF the way to go?
catphish
Post by catphish »
EV_Builder wrote: Fri Nov 05, 2021 11:39 am Isn't dextron IV ATF the way to go?
The short answer is "I have no idea". It's what they use in newer gearboxes, but that doesn't mean it's compatible with the older ones. Sadly I have no knowledge in this area.
EV_Builder
catphish
Post by catphish »
EV_Builder wrote: Sun Nov 07, 2021 3:11 am https://www.ebay.nl/itm/Lube-V-Full-Syn ... 632-2357-0
This might be an option.
Thanks, this definitely looks like the right stuff. I've emailed the UK manufacturer who seem to do a synthetic ISO 150, to ask them if theirs is equivalent to SHC 629: https://www.smithandallan.com/products/ ... -pressure/
catphish
Re: Tesla front SDU oil - Mobil SHC 629 alternatives  [SOLVED]
Post by catphish »
I've had a reply from Smith & Allan (UK Oil Supplier) who have stated that this product "Indisyn Oil Mild 150" is a direct replacement for SHC 629, so I'll go with it.
https://www.smithandallan.com/products/ ... aring-oil/
ViktorT
Post by ViktorT »
Hi Catphish
Did you get it right with the oil?
Alfa Romeo 147 with Tesla FDU and Kia soul pack
catphish
Post by catphish »
ViktorT wrote: Thu Jul 21, 2022 8:15 am Hi Catphish
As far as I know, yes. The drive unit has been running fine with it :)
