Sensor Board R3 Issues
Dakara0415
Post by Dakara0415 »
Greetings from Taiwan!
I have built the Sensor board R3 according to the wiki schematic. However I am not getting appropriate UDC outputs from the voltage sensing circuit. The main board cannot see any UDC. The ATTiny13 was bought from Digikey (off the shelf component), does it require to be programmed for it to work? Where to find this program for the ATTiny13 to suit?
I am very close to getting my motor to spin via FOC!
Thanks very much!
Re: Sensor Board R3 Issues
Oh, almost forgot this existed ;)
Yes it needs to be programmed, hex file attached.
volt_pwm.hex
(889 Bytes) Downloaded 149 times
main.c
(1.68 KiB) Downloaded 153 times
Dakara0415
Thank you for the swift response! :)
Dakara0415
Still no luck on getting the voltage sensor to work...
Just wanting a sanity check on my method, I have successfully uploaded and tried both the volt_pwm.hex file and compiled main.c to hex onto the ATtiny13, but still getting no where. Am I using the correct files? The main.c code looks like it was for your water heater project. Will it do the same job converting voltage input to pwm on the correct pins?
Thanks again :)
Oh sorry, that was silly! Of course I posted the wrong files. Will dig the correct ones from my archive tomorrow.
Ok, try that one!
volt_pwm.hex
(267 Bytes) Downloaded 148 times
main.c
(672 Bytes) Downloaded 153 times
