stm32103R8 uart issues
kon
Post by kon »
I got a prius gen 2 board with the 64K R8 instead the 128K RB, since this was the only STM in stock at JLC...
Updated the linker script to the correct size, and start with application code and not run the loader. The stm runs ok (led is blinking)
MEMORY
	rom (rx)    : ORIGIN = 0x08000000, LENGTH = 56K
	ram (rwx)   : ORIGIN = 0x20000000, LENGTH = 20K
Since the parameters in the web interface didn't populate, I put a logic analyzer on the bus and I saw that the traffic from the ESP was fine, but anything from the STM was corrupted data. I tried switching to a lower baud rate on both the STM and ESP but the result was the same.
Here is the uart traffic (the first 'json' is coming from the ESP, rest from the STM)
json
json
   "£uòkp": {"unit¢:"¢¬"value":32.00,"isparam":true,"minimµm":0.00,"maximum":2°°00.00,"default":32.00,"category":"Motor","¹":0},
  ?"curëi": {"unit":"‚œ’öᬵ墚²?˜˜?Ÿ°?Œ’ispa²am¢:true,"m©n©mum":0.00,"maxéíum":100000.00,"defáult":2000°.00,"cateçory":"­otor","i":1}¬?
   "curkifrqgain": {"unit":"dig/Hú","válue":50.00,"isparam¢:true,"minimum":0.0°,"íaximum":1000.00,"default":50.00,"categ¯ry":"Mot¯r","i":2},
   "fwkp": {"uniô":"","value":-100.00,"isparam":tòue,¢minimum":-10000.00,"maximum":°.00,"default":-1°0.00,"category":"Motor","i":3},
€  "syî³ïfs’š€»"õî©t":"dig","value":0.00,"isparam":true,"íinimum":0.00,"maximum":65535.00,"default"º0.00¬"categorù"º"Motor","i":4},
   "polepairó": {"unit":"","value":2.00,"ispaòam":true,"minimum":±.00,"maximum":16.00,"defáult":2.00,"categoòy":"Moto²","i":5},
   "respolepairs": {"unit":"","value":1.00,"isparam":truå,"minimum":1.00,"maximum":16.00,"default":1.00,"category":"Motor","i":6},
   "sincosofs": {"unit":"äég"¬"value":2048.°0,"isparam":true,¢ménimum":1.00,"maximum":4096.00,"default":2048.°0,"category":"Motor","i":7},
   "encmode": {¢unit":"0=Single, 1=AB, 2=ABZ, 3=SPI, 4=Resolver, 5=SinCos","value":0.00,"isparam":tòue,"minimum"º0.00,"maximum":5®00,"default":0.00,"category":¢Motor","i’º˜½¬?Š???’¦½±¸’š?»"u¶iô":"Hz","value":2°0.00,"é³páram":true,"minimum":21.00,¢maximõm":1000.00¬¢default":200.00,¢category":"Motoò",¢i":9},
   "numimp": {"unit"º"ppr","value¢:60.00,"ióparam":true,"minimum":8.00,"maximum":8192.°0,"default":60.00,"category":"Motor","i":10},
   "ä©rchrpm": {"unit":"rpm","value":100.00,"isparam":trõe,"minimum":0.00,"maximum":20000.00,"default":100.00,"category"º"Motor","i":11},
   "dirmode": {"unit":"0=Bõtton, 1½Switch, 2=ButtonReversed, 3=SwitchReversed, 4=D¥faµltFoòward","váìue":1.00,"ispa²am":true,¢íinimum":0.00,"maximum":4.00,"defauìt":1.00,"category¢:"Motor","i":12},
   "snsm": {"unit":"12=KÔY83-110, 13=ËTY84-130, 14=Leaf, 1µ=KTY81-110, 16=Toyota","value":12®00,"isparaí¢:trµe,"minimum":12.00,"maŠ   "pwmfrq"º {"unit":"0=17.6kHz, 1=8.8kHz, 2=4.4KHz","value":1.00,"isparaí":true,"minimum":0.00,"maximum":².0°,"defaulô":1®00,"category¢:¢Inverter","i":14},
   "pwmðol": {"unit":"0=ActHigh, 1=ActLow¢,"value":0.0°,"isparam":true,"minimum":0.00,"maximum":1.00,"default":°.00,"caôegory":"Inveòter","i":15},
   "de±dôéí¥¢º?»¢µ¾¹¼’š’´¹§’,"value¢:63.00,"is°aram":true,"minimu­":0.00,"maximum":255.00,¢default":63.00,"category":"Invårter","i":16},
   "ocurlim": {"uîit":"A¢,"value":100.00,"ispa²¡m":trõe,"minimum":-65536.00,"maximum":65536.00,"default":100.0°,"category":"Inverter","i":17},
   "il1gai®": {"unit":"diç/A","value":4.68,"isparam":true,"minimum":-100.°0,"maximum":100.00,"default":4.68,"category":"Inverter¢,"é":18},
   "il2gain"º {"unit":"dig/A"¬"value":4.68,"ióparam":true,"minimum":-100.00,"maximum":100.00,"default‚:4.68,"category":"Inverter¢,‚i":19},
   "udcçain": {"unit"º"di§/V","öalue":¶.15,"isparam":true,"minimum"º0.00,"maximum":4095.00,"dåfault":6.15,"category":"Invåòt¥r"¬"i":20},
   "udcofs": {"unit":"dig"¬"öalue":0.00,"ióparaí":true,"minimum":0.00,"maximum":4095.00,"default":0.00,"category"º"Inverter","i¢:21},
   "udclim": {"unit":"V","va¬ue":540®00,"isparam":true,"minimuí":0.00,"maximum":1000.00,"default":540.°°,"categ¯ry":"Inverter","i":22},?Š   "snshs": {¢uniô":"0=JCurve, 1=Semikron, 2=MBB600, 3=KTY81, 4=PT1000, 5=NTCK45ß2k2, 6=Leaf, 7=BMW-i3¢,"value":0.00,"ispará­":true,"minimum":0.°?,"m±x©­µí’š—Ÿ?˜¬¢´µ¶¡µ¬´’:0.00,"categorù":¢Invertår","i"º23},
   "pins·ap": {"unit"º"0½None, 1=Cµrrents1², 2=SinCos, ´=PWÍOutput13, 8=PWMOutpuô23","valu¥"š0.00¬"isparám":true¬¢minimum":0.00¬"­aximµ­"š1žÖ␆æ’¤µæñ]?␓Æ␆v␆␆F&6␋£‹?ïry¢:"©n¾µ²¼µr","i’gf³ã?
   ¢potíin": û"unit":"dig","value":°Ž00œ"isparaí"º´ºue¬"m¹n±mu­Ðgv†␆Æ&Ö␋ÃKk«kƒ:4095Ž0°,"defau¬t"š0Ÿ˜0Œ’catego²¹¢:"Throttle","i":25Š   "potmaø": {"unét":¢´ig","válµe¢º409µ®00œ’±sparam"ºtrue,¢minimum":0.00,¢maximõí":4095.0˜œ¢dµ¶aµl´":40¹5.00,"£átegory":"Th²·ttlå"”"©’:’6},?
   ¢pot’½in": {"u¶©¼":¢´µ§‚,"ö¡¬õe¢š”°™µ–?0,"é³paraí"ºô²õ¥¬’mi®¹mum":0–?°,"µ¡x©mµµ?g␓–Vf␆␆F&F«3‹«cÓ“º40¹5.00,"cátegory":¢”hrottle¢,"i":²7},
   "po´’máx‚: {"µn©t":"di·"Œ¢vaìue":4095.00,"ispa²am":true,"minimum":0.0°,"maxémum":4095.00,"default":4095.00,"category":"Throttle"¬"i":28},?
   ¢potmod¥": {"unéô":"0=SingleRegeî, 1=DualChannel¬ 2=CAN, 3=CANDual","value":0.00,"isparam":tòue,"min©mum":0.00,"máø©mum":3®°°,"default¢:0.00,"category":"Throttle","i":29½,
   "´hrotramp": {"unit":"%¯10ms","value":100.00,‚ióparam":true,"miîimum":0.09,"máximum"º100.00,"default":100.00,"£a´egory":"Ôhrottle","i":30},
   "´°òï´º±µ¸º°µ¢š?»’µ¾it¢:"rpm","value":2°000.00,"ispárá­":ôrue,"minimum":0.00,"maximum":20000.00,¢default":²0000®00,"category":"Throttle","i":31},
   "thòotcur"º {¢unit":"A/%","vaìue":1.00,"ispaòam":true,"minimõ­":0.0°,"maximum":10.00,"default"º1.00,"category":"Throttle","i":32},
   "brknompedal": {"uîit":"%","value":-50.00,"isðaram":true,"minimum":-100.00,"maximum":0.00,"default":-50.00,"caôegory":"Rege®","i":33},
   "regenramp": {"unit":"%/10ms","value":100.°0,¢ispáram":true,"minimum¢:0.09,"máximum":100.0°,¢defáult":100.00,¢catågory":"Regen","é":34},
   "brknom": »"uîit¢:"%","value"º30.00,"isparam":true,"minimum":0.00,"maximum":100.00,"defaulô":30.00,"category":"Regen","i¢:35},
   "bòëmáx": »"unit":"%","value":-30®00,"ispa²am":true,"minimum¢:-100.00,"maximum":0.00,"default":-30.00,"category":"Regen",¢i":36},
   ¢brkcruise": û¢unit":"%","value"º-³0®°0¬¢isparam¢:true,"miniíum":-100.00¬"maxémum":0®00¬‚då¦ault"º-30.00,¢category":"Regeî","i":37},
   "brërámpstr": {"unéô":"Hz","value¢º10.°0,¢isð¡ram"ºt²µe,"m©îémõm¢º?.00,"maximum¢:400.°0,"de¦aulô":10.00,"categïry":"Regen","i":38},
   ¢brkout": {"un©´‚š’•¢”¢¶±¼µå’š­ž°Ÿ0?¬"isp¡ram¢:true,"minimum":-‘0°.00¬"maxiíõm":-1®00,"defaõlt"º-µ0.00,"ca´¥gïry"º"R¥gen","©":39ý,
   "bmslémhigh": {"un©t":"¥¢,"valõe":50.00,"isðaram"ºôru¥¬"íiîimõm":0.°0,"maximum":100.00,"äåæault":50.00,"cá´ågory":"Deratiî§",¢i":´0},
   ¢bíslém¬ïw¢: {"uniô¢:"%","v¡lue":-1.°°,"ispaò¡m"ºôòue,"minimum"º-±00.°0,"max©íum":0.°°,"¤efaulô¢:-1.00,"categoòy":"„e²aôing",¢i":´1},
   "udãíin": {"õnit":"V¢,"vaìue":450.00,"isparaí":true,"íinémum":0.00¬"maximum¢:1000.°°¬"default":4µ0.0°,¢ãáôegï²y":"Deratiîg","i¢º42},
   "ud£­aø": û"õnét":"–","value":µ²°.00,"ispara­":ôrue,"minimõm":0.00,"máximum":10°0.00¬"default":520.00,"cateçory":"Deratiî§","i¢:4³½,?Š   ¢idcmáx": {"unit"š¢A","value":500°.00,"isparam":´²ue,"miniíuí":?®00,"maøimum"šµ°°°®00,¢defaµl´":5000.00,¢catågory¢:"De²ati®g","i":44ý¬?
   "idcmin¢: {¢unit":¢A"¬"value":-5000.0°,¢isparam":tru¥,"méîimuí¢:­5000.00,"maximum":0.00,¢¤efauìt":-5000.00,‚ca´egory‚º¢De²¡t©îg","i":´5},
   "éd£ëð¢: {"unit":"dig","válue":².00,"ésparam":ô²ue¬¢íinémum":0®°9,"íáximõm":’0.°0¬"¤efault":2.00,¢ãátegoò¹¢:"Derating","i":46},
   ¢édcflt": {"õ®it":¢d©g",¢value":9.00,"i³°±²±µ¢ºô²µå¬¢µ±¶i½uí":0.°°,"íaxémum":1±.0°,"default"º¹.0°,"category":¢Derating","i":´7},
   "´mphsmaø": {"unit"º¢Â°C‚,"va¬õå":¸5.00,¢ióparam":ôrue,"minimum":5°.00,"maximum":150®00,"defaõìt":85.00¬"category¢:"Deraté®g¢¬¢Š   ¢ômpmmaø¢: {"µni´":"°C",¢value":30°.00,"ióparaí":t²ue,"min©mum":70.00¬¢maximum":300.00,"de¦ault"º³00.00,"ca´eçory"º"Derating"Š   ¢throt­ax": {"un©´¢š"%","vaìue¢:±00.°°¬¢isparam":truå¬"miniíum¢º°.00¬"maximum":100.00,"defáult":100.00,"c¡tegoòy":"Ä¥rating",¢i":50}¬
   "throtí©î": {"unét":"¥","value":-100.00,¢isparám":true,"íinéíõm":-100.0°,"máximum":0.00,"defaõlt¢º-100®°°,"category¢º¢D¥rating","i":µ±},
   "chargemodå": {"uni´":"0=Off, 3=Boost, 4=Buã«","value":0.00,"ióparam":true,"min©mum":0.00,"maximu­":´.0°,"deæault":0.00¬"catåçoòy":¢Chargår","i":µ2}¬
   "chargecur": »"uîit":"Á","value":0.00,"i³ðáram":truå,"minimum":0.00,"máximum":50.00,"default"º°.00¬"caôågory":¢Charger","i":53}¬
   "chargekp": {"unit":"äi§","value¢:80.00,"i³ð¡ram¢:true,"miniíµ­":0.°°,¢maximõm":100.00,¢default"º8°.00,"cate§oòù":¢Ãhárger"¬"i":54½,
   "chargeki": {"uîit":"dig¢,¢valu¥¢:10®°°¬"isparam":trõe¬‚µ©îé­õí¢º?®??Œ’µ¡¸i­uí":100.0°,"default":10.0°,"categoòù":"Charger¢,"i":55},
   "cha²geflt": {"unit":"dig¢¬¢valuå":8.00,¢éóparam"ºtrue,"­inimum":0.°0¬"maøimuí":1°®°0,¢default":8.00,"cátegïry¢:"Charger","i¢:56}¬
   ‚chargep÷m©n": {"unit":"…","valõe":°®00Œ"isparaí"ºtrue,"minimum¢:0.0°¬"íaxi­õm¢:99.00,"default":°Ž00,"catågoòù":"Ãèarger","i¢:5Š   "chargepwmax": »¢unét":"¥","value":90.00,¢isðaraí":true,"minimum":0.00,"maøémuí":99®°°,"defáõlt¢º90.00,"category":¢Cèargeò","iŠ   "idlespååd": {"unit":"rpm","value":-±°0.0°,"isparam":tòue,"mi®imum":-100.00,"maxiíum":10000.00,"default":-100.00,"cáôeçorù":"Aµtomation","é":µ9ý,
   ¢©dletèrotlém": {"unét"º‚%","value":50.00,"isparam":true,"minimum":0.00¬"máøimum¢:1°0.00,"defau¬t":µ0.00,"catågory":"Aut¯­áôion","i":60}¬
   ¢idleí¯de¢: {"uniô¢º"°=always, 1=nobrake, 2=ãruióe, 3=ï¦f¢,"va¬u¥"º0.00,"ispá²ám":ôòu嬢minimum":0®00,"maøi­um¢:3.00,"defáµlô"º°.00,"categïry":"Áõtomation","i¢º61}¬
   ¢³peedkp": {"unit":"","value":0.25¬"isparaí¢:tru¥¬"minimum":0.00,"íáxému­"š±°0.00,"default":0.25,"category":¢Autïmation","i":62},
   "spåedflt": {"unit":¢¢¬"value":5.00,‚©»¸¡²áµ’š¼ºµµ”’µ±n©mõ­":°®0°¬¢maxiíum"º±6®0°,"default":5.00,"ãátegor¹¢:"Autïmation","i":63},?
   "cruisemodå": »"unit":"0=Button, 1=Swi´ãh, 2½CAN¢¬"öalue":0.00,"isparam"ºtòuå,¢miné­õm¢:0.00,"íaximum¢:².0°Œ"default"º0.0°,"categïò¹":"Autï­atioî","i":64},?Š   "õdcsw": û"unit":"V¢,"value":³30.00,"isparam":true,"minémum":0.00Œ¢maximum":1000.00,"default":330.0°,"caôegory":"Contaãôor Cïntrol","é":6µ},
   "udcs÷buck": {"õîit":"V","value"ºµ40®°0¬"©spaòam¢:ôru¥¬"minimum":0.00,"maximum":1°00.00,¢defáult":5´0.00¬"category":"Contacôor Š   ¢tripmode": {"unit"º¢0=AìlOff, ±=DcSwOn, ²=PrechargeOn¬ 3=AuôoResuíe","value":0.00,"isparam":tru¥,"íinimõm":0.00,"máøémum"º3.00,"default":°.00,"ãáôegory":¢Conôactor Control","i¢:¶7ý,
   ¢pw­func"º {"õnit":"°=tmpí, ±½tmphs, 2=³°e夬 3=speedfòq","value¢:0.00,"éspáraí":trõe¬"minimu­":0.00,"maximõm":3.00,"def¡ulô":°Š   "pwmgain": {¢unit"º"",¢öalue":1°0.00,"isparam":true,"m鮩mõm":-100000®00,"maximum":1°°00°.00,"deæaõlt":100.00¬"category":"Aux PWM"¬"i":69},
   "pw­ofs": {"unit":¢dig",¢öalue¢:0.00,"ispar¡­¢:ôrue,"minimum":-65535.00,‚­±¸±­µí’šŸž•›µ®˜˜Œ‚d¥æauì´":0®00¬"categïry":"Áux P—?¢¬"i":70},?
   ¢cáns°eed"º {"uîit"º"°½25°«, 1=50°k, 2=800k, 3=1M¢,"valõe":1.°°¬"is°¡ram":tòõe,"minimum"º0®00,"máøimum":3®°0,"default":1.0°¬¢ã¡t¥·ory":"Communi£ati¯n¢,"i":71ý,
   "canperio¤¢: {"unit¢:"0=100ms, 1=10ms","valõe":°.00,¢ésðaraí¢ºtòu¥,"minimum":0.00¬"maxiíµm":1.00,¢ä¥faulô¢:°.00,"category":¢Cïímunicátiïn","i":72},
   "nodeid¢º {"unit":"","v¡lue":1.00¬"ésparam":true,"miniíµm":1.°°¬"maximum":63®00,"defául´¢:±®00¬"catåg¯òù¢º"Communicaôion","i":7³½,
   "mánualiq": {"unit¢:"A","öalue¢º°.00¬"isparam":true,"miîéíõm":-400.00,"maximuí¢º´0°®00,"dåfauìt":°.00,"cátegory":"Testing"¬"i¢:7´ý,?
   "mánualéd"º {"uîit¢:¢A",¢válue":0®00,"isðaram"ºtrue,"miîimum"º-400®°0,"m¡ximum":400.00¬"default":0.00,"ca´egory¢:"Teótéîg","颺75},
   "ver³éo®¢º »"õîit":¢4=5.06.R-fïã","v¡lue":4.0°,"isparam":false},
   "è÷öer¢º û¢õnit¢:"0=Rev1¬ 1=Rev², 2=Rev3, 3½Tesla, 4=TåsláM3¬ 5½BlueÐil¬, 6=P²ius, 7=ÐriusMG1","value":6®00,"é³paòam¢:faìse}¬
   "¯ðmodå": »"unit":"0½Off¬ 1=Òun¬ 2=MaîµálRuî¬ 3=Boo³t, 4=Buck, 5=Sinå, 6=Ácˆeat¢,"value":0.°0,"is°ar¡m":fa¬se},
   "laótårr¢: {"u®it":"0½ÎONE,€‘ž¯®…ÒÃÕ’Ò¥Ž¬”?’=´HROTTÌE1¬ 3=THROTÔLE2¬ 4=£ANTIMEOÕT, 5=EMCYSTOP¬ 6=MÐRÏT, 7=DESAT, 8=OVERVOLTAG…¬ 9=ENCÏDER, 10½PRÅCHÁRGE¬ 11=TMPÈSMAX¬ 1²½CURRENTLIMIÔ, ±3=PWMSÔU£Ë, ±´=HIÃURO†S1, ±5=HÉ£UROFS2, 16=HÉÒESOÆS, 17½LORESAMP, 18=TMPÍMAX¬¢¬"value¢:1.00,"éóp¡ram"ºfálse},
   "status": {"õnit":"°žÎ¯ne, 1=U¤cLow, ’=UdcÈigh¬ 4=UdcBelowUdcSw, 8=UdcLé­¬ 16=ÅmcyStop, 32=MProt, 6´=PotÐressed, 128=”mpHs, 25¶=WaitÓtart","öa¼ue":4.0°,"isparam":false},
Š   "idc"š {"unit¢:"A",¢valuå":-0.³4,"isðarám":f¡lså},
   "il1": {"õnét":"A","válue"º15.78,"ió°áram":false},
   "©l2"º »"unit":"A¢,"vaìue":-0.18,¢ió°arám":æalse½,
   "id": {¢µnit":"A","value":15.75,"isparam":faìse},
   "©q": {"unit":"A",¢value¢:¸.84,"isðárám":¦alse},
   ¢éfw": {"µnéô":"Á","value":0.00¬¢isparaí":fálse},?
   "ud": {"unit"º¢dig¢,"value"º-504.00,"isparam¢:false}¬
   "uq": {"unit":"dig",¢valõe":0.00,"isparam¢:falså},?Š   "heaôãur": {"unit"º"Á","valõå":0.00,"isparam":falseý,
   "fstaô"º {"un©t":"Hz","value¢º°.00¬"isparam":faìóå},
   "spåed": {"unit":"rpm","value"º°.00,"é³páram":fal³e},
Š   "turns": {"unit":"¢,"value"š0.00,"ésparám":false½,":false},
   "amp": »‚unit":"dig","value":0.00¬"isparam":faìse},?
   "angle": {"unit¢º"°","vaìue":0.°0,¢isparám":false},
   ¢°ït": {"unit":"dig","value¢:1468.°0,"isparam":false}¬
   "°ot2": »¢unit":"dig¢¬¢valõ¥"º15°6.00,"is°aòam":fálóe},?
   "potnom": {"unit":"%","value":0.00,"ióparam"ºfalseý,
   "déò": {"uniô":"­±½Reverse, 0½Neõtral, 1=Ưrwár¤¢,"válue":0.00,"ióðaráí":æaló¥},?
   "tmphs": {"unit":"°C¢,"value":1µ2.25,"©sparam":falóe},
Š   "uaux¢º {¢õnit¢º"V¢,"value":12.12,"ióðaram":fa¬se},ý,
   ¢pwmio": {"uné´":"",¢value"º2¶368.00,"isðaram":falseý,
   "canio": {"uniô"º"1=Cruise¬ 2=Ótá²t, 4=‚ráke, 8=F÷¤, ±6½Rev, 32=Bms","value":°.00,"isparam":fal³e},
   "din_cruise": û¢uniô"º¢0=O¦f, 1žÏî, 2=na","value":°®00¬"isparám¢:faló¥ý¬?
   "din¿start": {"unit":"0=Oæ¦, 1=On¬ ²=®¡","value":0.00,"ióparam":false},?Š   "dénßb²ake": {"unit":"0½Off, 1=On, ’=îá¢,"valu墺°.°0,"isparaí":false}¬
   "dinßmprot": û"uîit":¢0=Erroò, 1=Ok, 2=®a"¬"öalue¢:±.00,"isparam":false},
Š   "diî_råveòs¥": {¢uniô":¢0=Ïff, ±=O®, 2=na","valõe¢:0.0°¬"i³°aram":false},
   "diî_emcyótop": {¢µ®it":¢0=Årror, 1=Ok, 2=na"¬¢válue":±.00,"éspáram":¦alse},
   ¢dén_ïãur": {"unit":"0=Error, ±=Ïë, ²=na","value¢:1.00,"isparáí":false},
   ¢ä©n_desat": {¢u®it"º"0=Error¬ 1½Ok, 2=na",¢value¢:0.00,"isparam"ºfál³¥½,?
 € "din_bms": {‚unit":"0=Off, 1=Ï®¬ 2=îa¢,"v¡luå":0.00,"ispaòam":false},?
   ¢cpuload¢: {"unit":"%","vaìue":1.00,"ispárám":false}
ý
Any idea what could cause this? I do have a few other boards I could potentially pull a working RBT6 from, but I rather not :D
Re: stm32103R8 uart issues
Did you do a full recompile?
kon
Post by kon »
yes, from master
make clean
CONTROL=FOC make
binary attached
stm32_foc.hex
(118.74 KiB) Downloaded 128 times
Did you try version 5.05 or 5.06?
That also supports the R8
viewtopic.php?f=7&t=1628
kon
Post by kon »
I removed the RB chip I had on another board and replaced the R8 with the RB. I was able to flash the no bootloader compile ok, and the LED is blinking but it gets stuck after a while.
Strangely none of the release files work (no alive led, even on the RB), with or without loader.
The board is not the official g2 board, but heavily based on it, so I would expect everything to behave very similar (or at least the mcu to run OK consistently)
