Mysterious R34 resistor rating for mainboard v3.4? Topic is solved
alehandro
When making the main board V3, I was faced with the determination of the nominal value of the resistor R34, it is installed on the finished version from Johannes, but it is not in the specification. Who can explain what R34 is used for and what is its resistance rating
Thank you for your help!
- Been thanked: 1914 times
Re: Mysterious R34 resistor rating for mainboard v3.4?
It is a pull-up resistor on the reset pin but according to the data sheet that is not needed. So I omitted it in the latest revision.
