Any charger with Tesla batteries? Topic is solved
JonMegaTron
Post by JonMegaTron »
Good evening,
Can I use any charger with Tesla batteries, or must I use a Tesla charger (and then install the opensource controller)?
Haven't been able to find the answer elsewhere and I don't want to waste a lot of money on buying a charger which may not work.
If I can use any charger, could you please send me some recommendations?
Jon :D
Has thanked: 176 times
Been thanked: 369 times
Re: Any charger with Tesla batteries?
JonMegaTron wrote: Fri Jan 22, 2021 9:51 pm Good evening,
Jon :D
as long as it out puts the correct voltage at a given rate, use what ever you like.
but sounds like you need to take a few steps back to understand what you are trying to do.
working with some potentially very dangerous components
JonMegaTron
Thanks for the answer!
I'm still a long way from even buying the parts, but I just wanted to start planning.
