Hi All,
Thanks for the great discussion! Learned a lot.
I am about to venture in the journey of buying a GS450h transmission, and I want to bench test the system with minimal voltage before I purchase a large battery. My question is, what kind of supply should I get for bench testing? What kind of voltage and current would I need to get the motor turning and verify all the subsystems. Or course, all this assumes that I have the appropriate inverter, and Damien's VCU.
Thanks!
Minimum Voltage for Bench Test
bobbyj_408
- mackoffgrid
- Has thanked: 6 times
Re: Minimum Voltage for Bench Test
I've not played with a GS450 before but from Damien's youtubes I think he has used quite low voltages such as 24v. So a couple of car batteries may get you going.
The original ni-mh battery pack from the same car would be pretty useful for bench testing I assume. Probably get it pretty cheap.
bobbyj_408
Great! I think I'll give two car batteries a shot. Fingers crossed!
I appreciated the informative discussion.
I'm ready to embark on the process of purchasing a GS450h gearbox, and before I invest in a sizable battery, I want to bench test the system with a low voltage. What kind of supply should I purchase for bench testing is my query. What voltage and current would I require to switch on the motor and test each subsystem? I work as chair.
nkiernan
- Has thanked: 518 times
- Been thanked: 95 times
4 off 12V car batteries in series gives 48ish volts and I've used this for bench testing my GS450H systems and with the Zombie and some restricted setting for testing purposes, it spins up to approx 1200rpm
