Hello
When i try to compiled source code inverter and charge get error
codeblocks 16 and 17 version
libopeninv/src/stm32_can.cpp|425|error: invalid operands of types 'void' and 'int' to binary 'operator>'|
and
src/inc_encoder.cpp|571|error: 'timer_get_ic_value' was not declared in this scope; did you mean 'timer_set_oc_value'?|
Some one can help me?
Not compiled code
Re: Not compiled code
When i try to make test , get this result .
test.h|20|warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]|
Just test some example project for codeblocks stm32. And all completely fine, no errors.
- Been thanked: 1918 times
Did you follow the instructions in readme.md ? Seems like you're not using the modified libopencm3
Yes, libopencm3 not correct.
Thank you.
Also when compiling your libopencm3
i see repeated error.
../common/timer_common_all.c: In function 'timer_get_ic_value':
1: warning: control reaches end of non-void function [-Wreturn-type]
You have same problem ?
Thank you.
