[FIRST DRIVE] Upcycling a Suzuki Samurai
hugow93
Has thanked: 27 times
Been thanked: 9 times
Re: Upcycling a Suzuki Samurai
Post by hugow93 »
Some small progress to update on:
- Last weekend I went to a nearby breaker's yard and got a radiator from a Toyota IQ. Compared to most modern cars the Samurai is tiny and this was about the only one that would fit the space available. I mounted it in the car yesterday, next weekend I'll plumb it in.
- The HVJB bug turned out to be a dodgey kilovac contactor which caused my precharge circuit to be bypassed and release some black smoke along the way :). Contactor now replaced, no more black smoke.
- I am ~80% done with the battery boxes. They're all mounted in position, I just need to figure out connectors and cable runs. 8 modules in the back, replacing the samurai back seats (having them was fun while it lasted), 2 modules mounted in the undercarriage where the petrol tank was, 2 modules mounted under the bonnet.
- Throttle bug overcome, but still needs some adjustment.
So at this point, I thought, "Why not enjoy my car a little when I have it at this quasi driveable stage? What about a jolly around the farm, or a single field, or the damn driveway? After all, did even you really believe you would get this far? Bask in the glory of DIY achievement."
Yesterday afternoon, tuning guide in hand, I set about making the Samurai drive again with 240v (just the 8 modules in the back, I need to figure out some proper connectors for the other two). First I checked the parameter DB for any Siemens 1PV tunes, none available but I could find one tune from JB on the land yacht pre makeover. This was my starting point. Here are my findings:
- Boost >4000 needed to get any movement from motor (expected as voltage is low)
- Fslipmin > 3.5 needed to ease the early shudders, but the shuddering kicks in again at anything above a crawl speed.
- Any boost value greater than ~6000 quickly leads to an overcurrent event.
- Overcurrent errors came up a lot. Plotting IDC as I went, the current never went over 20amps but the Overcurrent error still triggered (ocurlim was 100 amps as per Johu's A2 tune in parameter database).
- Car moved most smoothly in 2nd gear, but still got large shudders above walking speed.
So not much in the way of drivability yet.
First on the list is to try and figure out why I'm getting overcurrent, then I'll continue my attempts to tune out the shudder.
Note, inverter is wired for Reverse, as that's what generates forward motion through my transmission.
Converting a1994 Suzuki Samurai soft top
| Siemens 1PV5135 Motor | Gen 2 Toyota Prius Inverter + OI Control Board | 24 kwh Renault Zoe battery |
hugow93
Re: [FIRST DRIVE] Upcycling a Suzuki Samurai
Post by hugow93 »
I think this project is the first on the forum to combine an ACIM and the Prius Gen2 (there have been a couple to use the Gen3 and the Siemens Motor), so this may be of some broader interest (equally may be me just being a noob).
I've had the car driving for about a month now, but only in test capacity.
Initial tests used ~240v and ~300v.
These allowed me to move at crawl speed, but any increase in current led to motor vibration and eventual overcurrent shutdowns.
This was somewhat expected as the Siemens requires 215v on the bus, needing a DC source of >300v.
Last week I connected the full pack for ~370v, and had better performance.
However, I still can't make the car to move beyond a jogging pace.
Boost has to be kept below 3000 to allow full throttle without overcurrent or vibration, and I haven't been able to tune it perform any better.
I am very sure this is because I'm doing something silly.
I've posted the relevant parameters from the most recent test drive below, and any suggestions are greatly appreciated.
The motor is being run in reverse as that's what generates forward motion though the drivetrain.
Testing in 2WD.
Thank you in advance!
- Motor
boost 2800
fweak 300
fweakstrt 400
fconst 180
udcnom 0
fslipmin 3
fslipmax 6
fslipconstmax 5
polepairs 2
respolepairs 1
sincosofs 2048
encmode AB
fmax 150
numimp 64
dirchrpm 100
dirmode Switch
snsm KTY83-110
- Inverter
pwmfrq 4.4KHz
pwmpol ActHigh
deadtime 0
ocurlim 500
il1gain 4.68
il2gain 4.68
udcgain 6.15
udcofs 310
udclim 500
snshs JCurve
- Throttle
potmin 2200
potmax 4000
pot2min 1050
pot2max 3000
potmode SingleRegen
throtramp 100
throtramprpm 6000
ampmin 10
slipstart 50
sinecurve VoltageSlip
throtfilter 4
- Regen
brakeregen -50
regenramp 0.5
regentravel 0
offthrotregen -5
cruiseregen -30
regenrampstr 20
brklightout -25
- Derating
bmslimhigh 50
bmslimlow -1
udcmin 0
udcmax 500
idcmax 500
idcmin -500
idckp 2
idcflt 9
tmphsmax 150
tmpmmax 300
throtmax 100
throtmin -5
iacmax 5000
ifltrise 10
ifltfall 3
- Contactor Control
udcsw 300
udcswbuck 540
tripmode PrechargeOn
bootprec Off
- Aux PWM
pwmfunc tmpm
pwmgain 100
pwmofs 0
chentron
Has thanked: 42 times
Been thanked: 10 times
Post by chentron »
your project is very similar to my daihatsu terios project !!
unfortunately we are stuck at the same point.
If you get solve please let me know. I will do the same.
EV_Builder
Post by EV_Builder »
No expert yet on motor tuneing but the 4.4khz doesn't seem too high and also deadtime zero. Is something what caught my eye.
Are these correct?
RetroZero
Has thanked: 643 times
Been thanked: 64 times
Post by RetroZero »
Not a pro here, but how accurate are your gains for il1 and il2. It seems I had similar issues using 200v battery pack. There is a link somewhere as to how to test and calibrate them. Will try to find them tonight and link it in
Been thanked: 1913 times
Fweak seems much too high
Also I wonder if your encoder is hooked up correctly, the primary source for motors that rattle instead of spinning. Try swapping A and B
Inverter parameters are correct, no deadtime as Prius inserts it by itself
hugow93
Post by hugow93 »
Quick update on this project.
Thanks to the 5.35R software improvements and some guidance, I've got the Suzuki driving smoothly around the farm here.
Currently I have boost at 3000 and fw at 115.
That's driving in second gear.
Before doing much more tuning, I want to tackle BMS and charging.
The goal is to find solutions for both that are attainable with my technical competence. E.G. An early adopter version would be too much, I love the idea of using the AC inverter on the prius Gen2 for charging, but the hardware mods required likely to open a pandora's box of dodgy connections.
Considerations for BMS:
  • I've got a 22kwh 360v Zoe pack.
  • My Siemens motor is only rated at 215v, and I was close on gross vehicle weight when I had all cells in the car, so I've dropped four to give me 240v. There might be a future version where I upgrade the suspension, remount the other four cells and wire in parallel to keep voltage close to motor ratings and increase battery capacity. That's not this version.
  • I have the Zoe BMS and will use the loom, but as far as I can make out nobody is using the board at the moment.
Considerations for Charging:
  • I don't want/need fast charging. This vehicle is for short jaunts only, maybe just offroad use if getting it insured becomes too much of a headache.
  • I would love to use the MG1 on the prius for this if I could, but have only read the threads on the forum, I haven't tried it yet.
  • In theory, I have space for an outlander charger or equivalent. Preferrably I'd stick with the Toyota.
Anybody with thoughts and considerations at this point, would love to hear them!
