Page 2 of 3
Re: all in one board for open inverter project
Posted: Sat Jun 18, 2022 4:45 pm
by haliltepedelen
Romale wrote: Fri Jun 17, 2022 10:25 am In this case, the pull-up resistor is made by several kilohms and RG is calculated as before. When a positive pulse is applied, it passes directly through the diode D_ON and charges the Gate of the mosfet. When the output stage of the main driver is closed, then through the pull-up resistor PULL_DOWN opens Q_OFF and instantly discharges the Gate charge through itself, which leads to the instantclosure of the mosfet!
Also if we use toff transistor the toff path did not return the gate driver so negative bias voltage meaningles here i suggest to not use it. Now design has two seperate gate resistor for on and off we can arrenged resistor for fast discharge the gate
Posted: Sun Jun 19, 2022 8:59 pm
by Romale
Hi!
in the picture above, there is just one of the best solutions for managing powerful mosfets. I always use this and it works great
Posted: Sun Jun 19, 2022 9:05 pm
by Romale
But I don't know the whole scheme that you use, it can also be good. I would prefer a circuit with a locking transistor, for example Q_off IRFL9110TRPBF, pull_down 4.7K, D_on any schottky per 1 ampere
Posted: Wed Jun 22, 2022 12:50 pm
by haliltepedelen
Romale wrote: Sun Jun 19, 2022 9:05 pm But I don't know the whole scheme that you use, it can also be good. I would prefer a circuit with a locking transistor, for example Q_off IRFL9110TRPBF, pull_down 4.7K, D_on any schottky per 1 ampere
Hi
The design is done i shared the pdf files if there is no further update i will upload to github
schall-in-one-board-for-open-inverter-project--main.pdf
schematic
(2.32 MiB) Downloaded 443 times
layout
(8.24 MiB) Downloaded 507 times
3d
3d
3d
3d
Posted: Wed Jun 22, 2022 2:20 pm
by Romale
haliltepedelen wrote: Wed Jun 22, 2022 12:50 pm
Hi
Hello. I think everything is fine. I can try to make
Posted: Wed Jun 22, 2022 2:40 pm
by Romale
The only clarification is that all layers should be made as thick as possible, at least 75 microns, but it is better if 100 microns
Posted: Wed Jun 22, 2022 3:03 pm
by Romale
I noticed the absence of this place. how to program?
Posted: Wed Jun 22, 2022 4:54 pm
by haliltepedelen
Romale wrote: Wed Jun 22, 2022 3:03 pm photo_2022-06-22_18-01-44.jpg
Hello
I placed 4 pin header close to the microcontroller also can be programmed via esp8266
Posted: Wed Jun 22, 2022 5:00 pm
by haliltepedelen
Romale wrote: Wed Jun 22, 2022 2:40 pm The only clarification is that all layers should be made as thick as possible, at least 75 microns, but it is better if 100 microns
Ok i will make layer stack table for manufacturing
Posted: Wed Jun 22, 2022 5:01 pm
by haliltepedelen
haliltepedelen wrote: Wed Jun 22, 2022 5:00 pm
also high power path not painted can be supported vıa solder ıt will be reduced the board price
Posted: Wed Jun 22, 2022 5:02 pm
by haliltepedelen
Romale wrote: Wed Jun 22, 2022 2:20 pm
Hi
Now ı wıll make fınal check for production
Posted: Sat Jun 25, 2022 10:36 am
by Romale
haliltepedelen wrote: Wed Jun 22, 2022 5:02 pm Now ı wıll make fınal check for production
hi! Any news, friend?
Posted: Sun Jun 26, 2022 10:11 am
by haliltepedelen
Romale wrote: Sat Jun 25, 2022 10:36 am
Hi Friend
it is done
https://github.com/haliltepedelen/all-i ... project-V2
Posted: Sun Jun 26, 2022 9:05 pm
by Romale
Hi! I downloaded the files. I will send it in the near future for the manufacture of boards.
Most likely, they will install all the small parts there, but DC/ DC and power mosfets will already be bought separately and soldered ourselves.
Posted: Sun Jun 26, 2022 9:08 pm
by Romale
johu wrote: Mon Apr 25, 2022 7:16 am Oh cool, always wanted to do something similar but then OEM inverters came along.
What ratings do you expect and what file format / editor is it?
Hello. Would you also like one such board? I can make one for you at once and also send it for free, as a thank you for your contribution to home-made electric transport.
Posted: Sun Jun 26, 2022 10:38 pm
Thanks, yes it could come in handy
Posted: Tue Jun 28, 2022 2:58 pm
by haliltepedelen
Romale wrote: Sun Jun 26, 2022 9:05 pm
Hi
Some components added to design and i didn't share the bom yet please be aware thanks for your effort
Posted: Tue Jun 28, 2022 2:59 pm
by haliltepedelen
johu wrote: Sun Jun 26, 2022 10:38 pm Thanks, yes it could come in handy
Also i would like to thank you for such project
Posted: Sat Jul 02, 2022 9:19 am
by haliltepedelen
Hi
The BOM file is done.
Please refer to BOM file for exact component name and package.
I also uploded file to github
BOM.pdf
BOM
(314.84 KiB) Downloaded 544 times
Posted: Sat Jul 16, 2022 1:15 pm
by Romale
haliltepedelen wrote: Sat Jul 02, 2022 9:19 am Hi
hello. could you give an explanation on this "thing"
Posted: Tue Jul 26, 2022 6:47 am
by haliltepedelen
Romale wrote: Sat Jul 16, 2022 1:15 pm
Hello
This is room for every sheet you can delete it or it can stay
Posted: Tue Aug 09, 2022 8:45 am
by Romale
haliltepedelen wrote: Tue Jul 26, 2022 6:47 am
Hello
hello. I have a few questions. what voltage should c130-c153 be at? and also how to replace the sr2803 chip? I can't buy it anywhere. preferably something that can be bought in China
Posted: Tue Aug 09, 2022 9:35 am
by Romale
Something is wrong in the scheme. The output of the DC-DC has a voltage of 18.3, and the chip that it feeds is powered by 5V. Maximum 5.5.
Posted: Tue Aug 09, 2022 10:30 am
by Romale
I also could not find the ratings of these resistors:
R56,R57,R133,R134,R135,R136,R137,R153,R154,R155,R156,R157,R167,R168,R169,R170,R171,R178,R179,R180,R181,R182,R189,R190,R191,R192,R193,R200,R201,R202,R203,R204
Posted: Thu Aug 11, 2022 8:37 am
by yaroslav
Romale wrote: Tue Aug 09, 2022 9:35 am Something is wrong in the scheme. The output of the DC-DC has a voltage of 18.3, and the chip that it feeds is powered by 5V. Maximum 5.5.
Most likely there should be a dc/dc converter with an output of +5v
