Parameter database
- Been thanked: 1914 times
Re: Parameter database
The token parameter isn't mandatory. Can you post a screenshot where you're stuck?
- Has thanked: 91 times
- Been thanked: 517 times
Nevermind, it's worked today, the add.html page wasn't loading :S
Having issue updating a parameter set. "Parameter ID Not Found"
Edit, seemed to work after a few tries. Not sure what I did different.
I've downloaded my latest param.json but cant see how to update it from the website without going through the inverter UI. Is this possible at the min?
Had to check the code again. Seems the "Add Parameters" function doesn't expect the params.json but rather the output of 192.168.4.1/cmd?cmd=json%20hidden
Needs clarification I suppose...
jansondstan
