Parameter database
Has thanked: 369 times
Been thanked: 1543 times
Re: Parameter database
The token parameter isn't mandatory. Can you post a screenshot where you're stuck?
Has thanked: 82 times
Been thanked: 422 times
Nevermind, it's worked today, the add.html page wasn't loading :S
Having issue updating a parameter set. "Parameter ID Not Found"
Edit, seemed to work after a few tries. Not sure what I did different.
I've downloaded my latest param.json but cant see how to update it from the website without going through the inverter UI. Is this possible at the min?
Had to check the code again. Seems the "Add Parameters" function doesn't expect the params.json but rather the output of 192.168.4.1/cmd?cmd=json%20hidden
Needs clarification I suppose...
jansondstan
Post by jansondstan »
Thanks for this interesting information!
