- Been thanked: 1136 times
Weigh in for the rear drive unit.
- Has thanked: 479 times
- Been thanked: 314 times
Awww yisss.
Every time a new project's motor spins, an angel gets his wings.
That first wiggle of movement where you pump your fist in the air, nod to your buddies, and say "Fuck yeah!"
So, first power up of the M3 rdu inverter on the bench. Elon flashed some nice coloured leds at me and pumped out massive amounts of CAN on TWO busses. I took a sample for posterity. Up on the github repo for the can hackers
https://github.com/damienmaguire/Tesla- ... Drive-Unit
Now we can start the real hacking. Phase one : eliminate the musk, eliminate the problem.
Pin 124 of the TMS main processor is the reset pin called XRS. Pulling that to ground puts Elon asleep and leaves everything else up and running. Easy pickings for the upcoming HubenAtor XM-3000 modchip:)
- Kevin Sharpe
- Been thanked: 10 times
"time to get some sleep Elon... night, night"
https://twitter.com/EvBmw/status/123850 ... 38432?s=20
JeanVapeur
Hi Damian,
maybe this pictures helps you a little bit in your exploration...
Great to see the underside. Many thanks.
- Kevin Sharpe
Do you have any photo's of the power stage?JeanVapeur wrote: ↑Sat Mar 14, 2020 6:50 pm maybe this pictures helps you a little bit in your exploration...
- Kevin Sharpe
Some useful info in this article;Kevin Sharpe wrote: ↑Sun Mar 15, 2020 10:11 amDo you have any photo's of the power stage?JeanVapeur wrote: ↑Sat Mar 14, 2020 6:50 pm maybe this pictures helps you a little bit in your exploration...
ABOUT THE SIC MOSFETS MODULES IN TESLA MODEL 3
JeanVapeur
Anyone find a high res shot of the rear of the board? I'm getting a feeling old Elon is using bootstrap gate drivers:)
Yep. D421,D422and D423. High side bootstrap diodes:)
So a little more investigation reveals a Viper16A based power supply section used to generate the low side iso voltages. Not 100% sure as yet but looks to be derived from the hv. Can't say I like this. They're building cars not cheap mobile phone chargers. A multi output dcdc wouldn't have put them out of more than a few $...
elon busted my chops on this one but we have control of the mosfets:)
Great job Damien!Jack Bauer wrote: ↑Sun Mar 22, 2020 1:23 pm elon busted my chops on this one but we have control of the mosfets:)
First spin of a motor using the rear drive unit inverter. Switching at 17.6khz.
Current sensors seem to be easy. J2 header just below the phase terminals gives access.
Analog output of 2.5v at 0A. Measured the following :
Sensor B : 2.500V at 0A going to 2.487V at 1A and 2.4845V at 10A
Sensor A : 2.4980V at 0A going to 2.4964V at 1A and 2.4823V at 10A
And with Elon awake we get a 10khz sine wave as our resolver exciter that goes away when he sleeps .....hmmmm
Decided to take the plunge and give Kicad a go for the model 3 modchip. Intermediate schematic attached. Still need to add a few things like changing Uart2 to LIN for oil pump control etc.
M3_RDU_V1.pdf- (151.39 KiB) Downloaded 683 times
