[DRIVING] VW Touran powered by Nissan Leaf  [FINISHED]
Been thanked: 1116 times
Re: VW Touran powered by Nissan Leaf
Its been ages since I played with this but I have a fleeting memory of needing to set the limit voltage way higher to avoid the evse shutting down on overvoltage. In fact I think the jld505 software handles the current taper once target is reached.
Been thanked: 1913 times
Another attempt today. Good news: I can finally charge without ignition on :)
BMS current limits are relayed to the EVSE so I also don't need a sane target voltage. I set it to 450V and 460V limit only to discover that I still had the 410V constant in the CAN code :?
The longest stint was 2.5 kWh. After some random time it simply quits charging "as commanded by the vehicle". I couldn't see a state transition to ChargeEnd which would happen if the BMS signals a full battery. Also the commanded charge current was non-zero. Will retry later with the elevated voltage limit, maybe that was it.
Anyway the conclusion is that you do not need a dedicated CAN bus for ChaDeMo and also the EVSE doesn't care about the extra CAN messages.
Nice work. What brand was the fast charger? I remember some of them had terrible current regulation and would cause a kick in voltage that would trip the overvoltage limit. The higher the soc the more likely it was to occur.
It's the one on the picture. ABB if I remember correctly
Working through the list. Finished the rear brakes today, rerouted the charging cable, replaced the indicator inside the mirror. Before I replaced all cooling hoses with proper automotive hose and tidied up the LV wiring.
Only wishbone bushing to go.
There is also something with my battery mount, don't know specifically what exactly though. Hard to reach anyone. I'm hoping it won't open up a rabbit hole.
Been thanked: 411 times
johu wrote: Thu Apr 09, 2020 8:35 pm There is also something with my battery mount, don't know specifically what exactly though. Hard to reach anyone. I'm hoping it won't open up a rabbit hole.
What do they say exactly? I know if you have the battery inside the cargo compartment you need to fasten it to the force of 10G.
But if you have it under some sacrificial construction then you can make a finite element analysis (bolts) and approximate shear force to 4G since the metal around battery will help hold it in case of collision. Same goes for the under the hood battery. There hood cover helps you retain battery in case of frontal impact. I allways use tempered steel 10.9 bolts to fasten battery down. I think 12.9 are overkill and a bit brittle.
It says "Befestigung Batteriesatz ungenügend" - "Mounting of battery insufficient". But no further details. I looked up data sheets for the mounting brackets and each is rated 2300N (I use 3). The rear ones are rated 10kN. The middle ones I couldn't find data for, it is a 3mm 50x50mm aluminium profile.
So say the total supported force would be 3x2300N + 4000N (assuming thats what the aluminium holds) we would be at 10.9kN. One brick weighs 90kG so at 4G we are talking 3.6kN. In other words the mounting would withstand 12G.
Apart from that I made a new video:
Kevin Sharpe
Been thanked: 10 times
Post by Kevin Sharpe »
johu wrote: Mon Apr 13, 2020 12:33 pm Apart from that I made a new video:
Great video :)
FYI it's still showing as "unlisted" on YouTube
Kevin Sharpe wrote: Mon Apr 13, 2020 12:36 pm Great video :)
Thanks :) First time with camera woman.
Yes it's unlisted: first appears for Patreons, then forum, then for all.
Thanks for sharing on twitter!
rikohm
Post by rikohm »
"Mounting of battery insufficient" could they mean your 12v battery? Couldn't make out from the video if it was fastened inside the box..
RetroZero
Has thanked: 643 times
Been thanked: 64 times
Post by RetroZero »
Nice one Johannes, enspiring video!
rikohm wrote: Mon Apr 13, 2020 8:25 pm "Mounting of battery insufficient" could they mean your 12v battery? Couldn't make out from the video if it was fastened inside the box..
I think you need to extrapolate in your technical report what you wrote here. So make an "engineering judgment" by using finite element analysis = bolts and prove them you were accounting for normal eventualities. They should be OK with that.
Oh... i just remembered that "screws" are used to only carry load in one direction (up - down) due to threads along their whole length which weaken them for shear loading. You get them in temper 8.8 which i deem insufficient. Its bearing strength is almost on par with construction Al alloy.
While "bolts" which have smooth surface for a good length of their body with threads only at the end are also used to carry some shear loads. They are usually to be found in different tempered states. Like i say i use 10.9 temper.
Maybe they think you should have used more bolts?
Also i use bolts and washers so that smooth part of the bolt is outside the bearing member for a milimeter or two and washer is raising nut so there are still 2 or 3 threads left...
Did you use bolts or screws on your mounts? I dont remember anymore. Could be that they deem they cant withstand shear (side) loading in an impact.
Yes I was hoping for that. It is indeed not fastened - just by its terminal :? Used to be 40Ah cells that fit vertically but they were deep discharged and destroyed... So quick replacement.
The co-engineer told me it was something with the main pack.
arber333 wrote: Mon Apr 13, 2020 9:28 pm I think you need to extrapolate in your technical report what you wrote here. So make an "engineering judgment" by using finite element analysis = bolts and prove them you were accounting for normal eventualities. They should be OK with that.
Yes I did, only the 12G estimate was something I came up with after reading your post again. Will give them a call tomorrow to clear things up.
arber333 wrote: Mon Apr 13, 2020 9:28 pm Did you use bolts or screws on your mounts? I dont remember anymore. Could be that they deem they cant withstand shear (side) loading in an impact.
Only screws with threads all the way. You know the chassis has 5 "nuts" integrated and you drilled the other 3 holes :)
johu wrote: Mon Apr 13, 2020 9:40 pm Only screws with threads all the way. You know the chassis has 5 "nuts" integrated and you drilled the other 3 holes :)
Right! 8-)
Got mail from celeron55 today :) 3D-printed ChaDeMo plug complete with pins and cable - thanks very much!
Not using the CAN line yet as the charger still uses a Gen1 mainboard w/o CAN.
Apart from that it works fine and prevents the car from driving off while plugged in.
JaniK
Has thanked: 101 times
Been thanked: 15 times
Post by JaniK »
Great stuff celeron55 :)
And johu, much easier to develop code now?
So another TÜV visit today. No result yet, he will check next week.
More importantly I fast charged from 20-80% without interruption and with 35kW 8-)
On the way I accelerated to 160kph in 4th I think there is more in a higher gear.
mdrobnak
Post by mdrobnak »
johu wrote: Thu Apr 23, 2020 10:56 am So another TÜV visit today. No result yet, he will check next week.
Nice! Were the fixes for the fast charging difficult, or one of those 'the details will get you' kind of thing?
-Matt
I don't even remember exactly. I think two main things I was asserting the charge allow flag to late and I stopped charging when the charger signaled "stop". Which really just meant "I have not yet started charging".
Look here: https://github.com/jsphuebner/stm32-car ... dfa101ad31
It's done :D :D
Picked up Touran from TÜV today.
I would say it was not so hard. Just a bit pricey at roughly 600€, 300 of which were for the rather redundant noise test.
celeron55
Has thanked: 39 times
Been thanked: 136 times
Post by celeron55 »
Nice! Receiving one of those "not exactly for the average citizen" papers is always fun.
RetroZero
Post by RetroZero »
FÉLICITATIONS, CONGRATULATIONS 🎊.
Here's to many more Johu!
mike77cos
Has thanked: 9 times
Post by mike77cos »
Congratulations on passing
Kevin Sharpe
johu wrote: Mon May 11, 2020 8:13 pm It's done :D :D
Well done, that's very cool :)
Thank you all very much :)
So next video will be "taking Touran from Kassel to Saarbrücken (400km)". Lets see what surprises the German fast charging network comes up with :P
