Ah yes, Flux-Core, boy do I not miss the splatter. I started out with one of them Cardboard Freight units, and one day my buddy who used to weld for Caterpillar [pronounced bad ass welder] came over and gave that little box a try, I swear he almost tossed it across the garage, he looked at me and said, it aint you Greg, this thing is a piece of junk !!! a few weeks later I bought myself a proper MIG machineMattsAwesomeStuff wrote: ↑Thu Apr 30, 2026 12:36 am Bondo Billy is excessively eccentric, but seems to know his stuff. He's the guy I wish I would have found when I welded my two cars together with an old POS flux-core welder. The secret to using flux-core for autobody work is to have large stick-out, like, 3/4"-1". And then instead of being a manageable consolation, it actually has less deformation than proper gas-on MIG welding.
Bunky the eBug: A 30 Day EV Conversion
- Gregski
- Has thanked: 635 times
- Been thanked: 1610 times
Re: Bunky the eBug: A 30 Day EV Conversion
It really does depend on the MIG welder quality, I bought a Michigan cheapie gas/gasless welder ($300) after loosing three good high priced machines, a Unimig Razor Pulse 200 that cost me $3500 if you include the trolley and two gas bottles that you own rather than rent, I used once before the house and motorhome and house garage burnt to the ground, the other two were in the workshop when it burnt to the ground.
The essentials:
they need a very good power supply, including the supply cable from the 15 amp 240vac dedicated power point, the welds will be rubbish if you have voltage drop due to poor electrical supply.
The quality of the flux core wire, cheap rubbish wire will result in a splatter covered crap welds
And the golden rule, if it's got slag, ya gotta drag, so the weld pool is after the wire, not before like gas mig welding ....
T1 Terry
I rebuilt a tilt trailer to carry my MG4 EV behind the motorhome with that $300 gasless Mig welder
The essentials:
T1 Terry
Taking on more projects than I have yrs left in me, but, not dead yet, so far, so good
One thing that has me puzzled, and I know I'm very late to this build, why did you add the plate that used the 2 seatbelt mount bolts on the body, rather than just the gearbox mounting point of the floor pan come chassis that makes the VW beetle so special?
The body that bolts onto the floor pan has no real structural strength and the whole floor pan actually moves somewhat independently to the body that's bolted on top of it .... all the mount hole are slotted for this reason, the body shifts on the rubber seal between the pan and the body .....
I do like your approach to mounting the motor, I might copy a few of the ideas when I put the 150kw MG4 rear motor in my VW Kombi Campervan .....
T1 Terry
T1 Terry
- Gregski
Oh no Terry, I hope everyone was ok, and I know how it sucks having to rebuy the tools you once already had, let alone high quality ones.T1Terry wrote: ↑Thu Apr 30, 2026 3:54 am It really does depend on the MIG welder quality, I bought a Michigan cheapie gas/gasless welder ($300) after loosing three good high priced machines, a Unimig Razor Pulse 200 that cost me $3500 if you include the trolley and two gas bottles that you own rather than rent, I used once before the house and motorhome and house garage burnt to the ground, the other two were in the workshop when it burnt to the ground. [...]
- Gregski
a little buy me some time update, while we wait on more parts:
- Has thanked: 479 times
- Been thanked: 314 times
